New iOS App for domoticz
LanWolf
Re: New iOS App for domoticz
Post by LanWolf »
Is still possibel i would like to test. Did this for pilot, the other ios app too.
*/ Just A Byte /*
LanWolf
Post by LanWolf »
Wel after install a few quick notes:
Scenes are shown as switches, and no status is pulled.
It starts with the verbruik screen, please make a sort of home screen with favorites, or let the user chose his startup screen.
The list of switches is long, maybe make the room choosable from the top bar?
I don't know if you know the home wizard app? They had a top with 2 rows of icons with favorite temp, usage, alarm, motion things. Then followed by the dashboard, with favorites (scenes, switches and other)
That was one of the most informative screens I ever saw on startup of an home automation app on my phone/ipad
*/ Just A Byte /*
LanWolf
Post by LanWolf »
0.5(6)
In the favorites extension, it does not show correct status, lights which are on are shown off, although they are shown correct I the app.
No sliders for dimming are shown, it's that correct?
In favorites only switches are shown, is that correct?
I would like to select which lights/scenes are shown, showing all favorites and all scenes is bit to much for a widget imho.
*/ Just A Byte /*
a3vd
Post by a3vd »
Sliders are available when you push the switch.
I can't read my electricity which comes from my other raspberry , but is installed as an device on the control raspberry.
Will do some checks this evening !
Raspberry 3+ / 4
P1 smartcable / RFXtrx433 FW 182 / Several 1 wire Temp Sensors /DHT12/Conbee2 (zigbee)
Several Kaku switches/ Weather Underground / Hue
simonrg
Domoticz version: 3.8807
Post by simonrg »
I like the way the sliders only appear when you switch a dimmer on.
I don't have gas, and my electricity has 3 different single phase supplies so I need to be able to customise the Usage page, as currently it displays nothing. How do I configure it?
The simple switches work well for Groups on the Scenes page with Group On / Off being obvious, but don't work for Scenes as I always get a "Connection to domoticz has been lost - Please review your settings". Probably Scenes should be a push button which bounces back after being pushed.
I have a lot of switches both virtual and real, so swapping between Scene and Switches pages is quite slow, it would appear Domotix is not caching the switches, really want instant page change, even if updating of the page takes a few seconds.
Great start, as others have said some configuration options to allow seclection of subsets of switches, customise start-up screen and create a favourites pages is needed.
Thanks, Simon
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Shyam
Post by Shyam »
This is great! I was testing the geolocation and it's awesome!
Only thing is that I had to restore my phone, and the app is gone from testflight. Would you be able to add me back on?
Cheers
Shyam
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
Accenta Gen4 Security System Integration
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Blog: http://www.shyambhundia.com
Dynamic
Post by Dynamic »
I'm using the app for a week now and I'm loving the switches in the today-screen. There is no faster access to my switches than this way!
I thought it was mentioned before, but I would suggest to cache the switches and states. Now there is a slight delay when opening the today pane.
mvveelen
Post by mvveelen »
Love the latest version and the 'usage' :)
One thing though.....I might be overlooking something, but how do I use the location services? I can set my location, but how can I let a certain switch be switched with this app?
Edit: found it :)
Other question: how can I get the switches on my homescreen (iPhone) ?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
Shyam
Post by Shyam »
The switches on the today section are awesome! Can you dim lights with them? would be nice if you could swipe the section to control the brightness :)
mvveelen wrote:Love the latest version and the 'usage' :)
Go to the Today section (swipe down from the top) then go to edit, you will be able to edit what is widgets gets shown.
How did you get the location services working? Am I right in assuming that I need be in the area first to set it up? or can i search for a location?
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
mvveelen
Post by mvveelen »
Ok, that worked :)
You have to make the virtual switch you want to be set, a 'motion sensor'-switch. If you do that, Domotix will recognize it and you can select it.
Shyam
Post by Shyam »
mvveelen wrote:Ok, that worked :)
Do you know how to select the location on the map
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Zetti
Post by Zetti »
Just a quick message to propose myself for the betatesting of the application. I can also help later in the App's translation in another language.
AdiLoop
Post by AdiLoop »
Have you collected your 20 pilots?
Im interested to participate but cant send any privat PM's just yet.
Bergemr
Post by Bergemr »
Still need testusers?
pepijn
Post by pepijn »
mfranken wrote: - 20 have registered, so I won't accept new requests for a while.
Please read the previous posts
iMiMx
Post by iMiMx »
All looks very promising, looking forward to the release, especially the Today screen widget - this is something I really miss from the iConnectHue app, which I think they have absolutely nailed as it allows on/off, scene recall and dimmer control.
LJ80
Post by LJ80 »
I would like the posibility to see times is that possible?
For example, when you click on a door sensor a list will open with times of open and close.
Shyam
Post by Shyam »
I'm still having issues with the location services. Its most probably me not using it correctly.
I've selected the sensor and set the location, but the sensor does not switch to on if im in that location.....
any idea?
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
mfranken
Post by mfranken »
Shyam wrote:I'm still having issues with the location services. Its most probably me not using it correctly.
any idea?
Did you allow domotix to track your location, when you were first asked? Check your (iPhone's) Settings -> domotix -> location (it should say always)
Raspberry, RFX, Zwave, JeeNodes, MySensors, OTGW, Domotix iPhone App
Shyam
Post by Shyam »
any idea?
Yep, the tracking is on, and i see the location arrow on top, but it only switches the motion switch on when i enter the application.
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
