Monit works partially
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
jvmaanen
Post by jvmaanen »
If the power of the raspberry has been off, it takes more than half an hour before domoticz is restarted. This happens after the script has performed the reboot.
I'm using these lines:
check process domoticz with pidfile /var/run/domoticz.pid
start program = "/etc/init.d/domoticz.sh start"
stop program = "/etc/init.d/domoticz.sh stop"
if failed
host 127.0.0.1 port 8080 protocol http
and request "/json.htm?type=command&param=getversion"
and content = '"status" : "OK"'
for 3 cycles
then restart
if 5 restarts within 5 cycles then exec "/sbin/reboot"
It looks like the "if failed" part is not working correctly.
When I check the Monit web page, I get the following error:
Monit error for Domoticz process.png (48.89 KiB) Viewed 1077 times
After more than half an hour, the raspberry has been rebooted based on the "If 5..." statement and then after 5 minutes the domoticz server is finally started.
Monit succesfully started domoticz.png (62.14 KiB) Viewed 1077 times
What is wrong in the "if failed..." statement and how can I test this on the raspberry (terminal).
Kedi
Re: Monit works partially
Post by Kedi »
I don't understand the "it takes more than half an hour before domoticz is restarted"
I suppose the script "/etc/init.d/domoticz.sh" is present, which should start domoticz right after the boot.
The default monit install has a 'start' delay of 60 or more seconds before it starts checking.
After that delay domoticz should already be up and responding to monit requests.
And beter change
in
start program = "/etc/init.d/domoticz.sh restart"
jvmaanen
Post by jvmaanen »
It surely helped a lot changing from start to restart.
There is still a difference between a reboot command and a power failure. After a reboot command domoticz is running, after a power failure domoticz is started, but not running:
pi@raspberrypi:~ $ sudo service domoticz status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Sat 2024-08-31 10:17:16 CEST; 7min ago
Also the pidfile at /var/run/domoticz.pid is not available
After 5 minutes Moni becomes active and now restarts domoticz. Domoticz is now running again:
Active: active (running) since Sat 2024-08-31 10:27:08 CEST; 1min 7s ago
So, I still need Moni to activate domoticz, but with the restart option (instead of start) it now takes 5 minutes after the boot when Moni starts who checks for the missing pidfile and restarts domoticz. After the restart domoticz is active and running. In the previous situation I had to wait more than 30 minutes for the reboot command to kick in.
Kedi
Post by Kedi »
Then there is something wrong with your system.
In both case (reboot / power failure) Domoticz should start directly after the system is started up.
B.t.w. I use a start delay of 60 seconds for Monit to do its job.
jvmaanen
Post by jvmaanen »
It looks like it starts after a power failure, but than exits. When I check there is no pidfile.
What can I do or check, to make sure that it starts correctly?
Kedi
Post by Kedi »
Put on complete debug logging and simulate power failure. See wiki for howto.
In that logging should be a cause.
Post (partial) logging here as attachment or spoiler.
Don't forget to put normal logging back.
Domoticz version: 2024.7
What version of Domoticz are you using? The issue that Domoticz stops right after a cold reboot (power off) because of the time difference should be fixed in recent versions.
Another option is to have a extra Domoticz startup delay parameter on your environment so it will be sure the time has been synced before Domoticz is started. See for more info wiki page https://www.domoticz.com/wiki/Troublesh ... _cold_boot
jvmaanen
Post by jvmaanen »
Updating to the latest version solved the problem. I tested this several times. Now domoticz starts right after the power has been restored.
Thanks for all the advices.
