Stoll error after device creation
Filip
Post by Filip »
I have the same issue after moving from a 2023 version to the 2024.7 on a raspberry pi.
Version: 2024.7
Build Hash: b317cfab1
Compile Date: 2024-07-13 16:59:31
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Mar 12 2021, 04:06:34) [GCC 10.2.1 20210110]
The error happens immediately when the device is created and without any update that happened.
The device creation:
Domoticz.Device(Unit=_UNIT_MILEAGE_COUNTER, Name='Mileage (Day)', Type=113, Subtype=0, Switchtype=3, Options={'ValueUnits': 'km'}, Image=Images[_IMAGE].ID, Used=1).Create()
Wouldn't there be a problem with the initialisaeention?
Anybody that could help?
Kr,
F
gizmocuz
Re: Stoll error after device creation
Post by gizmocuz »
This means that the value (sValue) in the database is not correct, is this empty or an empty string?
What happens when you set this to 0 ?
Filip
Post by Filip »
Hi, thanks for the feedback...
I checked with an SQL viewer earlier and the sValue was indeed empty.
I am almost sure that setting it to 0 would help. Even when I thought about it, I was not eager to change directly in the database to avoid side-effect problems.
I checked if it was not possible to give an initialization value with the creation of the device (to force 0), but this was not the case.
Currently I restarted the plugin without the device, but would like to activate back at a certain moment so any recommendation could help.
(btw: it is about https://github.com/FilipDem/Domoticz-BM ... /tree/main).
F
