Hello all,
My configuration :
Version: 2024.7
Platform: Ubuntu 20.04
Plugin/Hardware: GPIO pins/Odroid C2
When generating the GPIO hardware that was first configured with a bash job i get negative Unit values for the detected hardware when using Generic sysfs GPIO . When trying to toggle a GPIO pin trough Domoticz I get an error "sending switch command".
Bash commands work fine and change the GPIO pin correctly, also without a sudo command.
After an update and upgrade the error stays
This problem occurred recently, the configuration worked fine before.
I seems that the value equals the GPIO pin assignment in linux minus 256
When making a dummy switch and assigning a script that turns on and off the GPIO output all works fine.
Anyone that can explain why I get negative Unit values when using the Generic sysfs GPIO Hardware option of Domoticz?
When trying to add a switch manually, Domoticz shows the correct pin assignments in the selection list but I have no idea what to enter as ID, 3 0E 0E 04 as ID values gives the same error message.
Greetings,
Luc De Smedt
Negative Unit values are displayed when generic sysfs GPIO generates the confugered hardware Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- gizmocuz
Re: Negative Unit values are displayed when generic sysfs GPIO generates the confugered hardware
There have been some recent changes to the sysfs/GPIO hardware.
It seems this negative unit is assigned in the sysFS/GPIO hardware class, as I just changed manually a device unit to 249 here in the database, and it displays correctly in the devices overview.
Just had a look at the hardware class, it seems 'int8_t' was used instead if 'uint8_t', and this is causing the negative number
Could you try beta 16179 to see if this solves the issue?
- Domoticz version: 2024.7
I'll give it a try this evening. Thanks for the information.gizmocuz wrote: ↑Monday 19 August 2024 8:09 There have been some recent changes to the sysfs/GPIO hardware.
I installed beta 16182 and all works fine now. One more man feels happy. How do I close this issue ?
- gizmocuz
Great it's working!
Consider it closed
Consider it closed
