Unauthorized error
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
marktn
Unauthorized error
Post by marktn »
I'm not sure if it's a Node-RED problem or domoticz, but I'm experiencing an issue after removing 192.168.1.* from my trusted networks.
I want to do this because more users are accessing the WebUI.
When I paste this URL into my browser, it works fine:
http://192.168.1.5:8080/json.htm?type=c ... vvalue=100
In Node-RED, I use an HTTP request node with the same URL. It works when 192.168.1.* is included in the trusted networks.
However, without 192.168.1.* in the trusted networks, I get an error in Node-RED:
"<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>"
I do have the IP address of Domoticz/Node-RED (192.168.1.5) in my trusted network.
Do you have any idea how to solve this? I've read the wiki but couldn't find a solution.
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
jvdz
Domoticz version: 4.107
Re: Unauthorized error
Post by jvdz »
The Wiki has quite an elaborate explanation how the security works: https://www.domoticz.com/wiki/Security
You probably need to read this part for this question: https://www.domoticz.com/wiki/Security#API_Protection
marktn
Post by marktn »
jvdz wrote: Friday 16 August 2024 14:13 The Wiki has quite an elaborate explanation how the security works: https://www.domoticz.com/wiki/Security
Thanks! You pointed me in the right direction.
I made a screenshot with the solution, use authentication in the node.
gizmocuz
Post by gizmocuz »
Please try to use HTTPS as that is safer.
Not sure how long basic authentication for HTTP will keep on working
Anyone sniffing your internal network will be able to decode the username/password when using HTTP
https://en.wikipedia.org/wiki/Basic_acc ... entication
janpep
Domoticz version: 2025.1
Post by janpep »
Is it correct that this "401 Unauthorized" message does not appear anywhere in the log or am I missing something?
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
marktn
Post by marktn »
janpep wrote: Tuesday 20 August 2024 21:35 Is it correct that this "401 Unauthorized" message does not appear anywhere in the log or am I missing something?
Not in domoticz but in nodered Debug.
janpep
Post by janpep »
marktn wrote: Wednesday 21 August 2024 10:20 Not in domoticz but in nodered Debug.
Thank you. Clear.
Actually strange that Domoticz does log a failed login, but not an unauthorized connection attempt.
Users browsing this forum: janpep and 1 guest
