SBFSpot SMA
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
johnnix
SBFSpot SMA
Post by johnnix »
Hello all,
I hope this is the correct place to ask my question.
I have SBFSpot running on my pi4 and tried to setup Domoticz and I am having an issue seeing the battery percentage. In devices I see a BT_Signal dispalying data 0% and in Settings->Energy Dashboard in Battery SOC I do not see another option tan Disabled. Can anyone please provide some insights of what I did wrong?
Kindest regards
John
Domoticz version: 2024.7
Re: SBFSpot SMA
How did you link your SBFSpot data into Domoticz? Is a battery supported?
Do you see a battery device in Domoticz?
Re: SBFSpot SMA
If you are using the standard SFBSpot integration then there is no battery support implemented yet.
If you have mqtt already you could use the mqttmapper plugin to add the values.
johnnix
Re: SBFSpot SMA
Post by johnnix »
Thank you very much for your reply!
I would really like to see the battery level but unfortunately I am not familiar with mqtt.
Kindest regards
John
