Hello all,
I hope this is the correct place to ask my question.
I have SBFSpot running on my pi4 and tried to setup Domoticz and I am having an issue seeing the battery percentage. In devices I see a BT_Signal dispalying data 0% and in Settings->Energy Dashboard in Battery SOC I do not see another option tan Disabled. Can anyone please provide some insights of what I did wrong?
Kindest regards
John
SBFSpot SMA
- Domoticz version: 2024.7
Re: SBFSpot SMA
How did you link your SBFSpot data into Domoticz? Is a battery supported?
Do you see a battery device in Domoticz?
Re: SBFSpot SMA
If you are using the standard SFBSpot integration then there is no battery support implemented yet.
If you have mqtt already you could use the mqttmapper plugin to add the values.
Re: SBFSpot SMA
Thank you very much for your reply!
I would really like to see the battery level but unfortunately I am not familiar with mqtt.
Kindest regards
John
Kindest regards
John
