ESP32-CAM as doorbell with camera Topic is solved
finch666
Domoticz version: 2022-1
Re: ESP32-CAM as doorbell with camera
Post by finch666 »
hmm, I can't seem to figure out at which hex addresses the bin files should be placed. :?:
Tried 0x10000 for firmware.bin and 0x4000 and 0x25000 for spiffs.bin, but that does not work.
I'm using the esp32 download tool from espressif.
Can I find the addresses somewhere?
Update: finally managed to build and upload a spiffs.bin through platformio and upload the firmware.bin with the esptool and got it working now. I'm guessing there have been some changes in the platformio configuration that made it impossible to build the firmware.
Other update: uploaded tasmota webcam software to the ESP32 cam. Works like a charm.
ronh123
Post by ronh123 »
Did anyone install an esp32 cam these days. I installed latest Visual Studio Code, folllowed the instructions but keep getting:
Compiling .pio\build\ESP_4096\lib4b7\FS\FS.cpp.o
Compiling .pio\build\ESP_4096\lib4b7\FS\vfs_api.cpp.o
In file included from C:/Users/ronho/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal.h:76,
from C:/Users/ronho/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:36,
from C:/Users/ronho/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiClient.h:24,
from C:/Users/ronho/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFi.h:37,
from src/Main.cpp:7:
src/Main.cpp: In function 'void setup()':
src/Main.cpp:111:18: error: 'TAG' was not declared in this scope
ESP_LOGE(TAG, "An Error has occurred while mounting SPIFFS");
C:/Users/ronho/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-log.h:159:72: note: in definition of macro 'log_e'
#define log_e(format, ...) log_printf(ARDUHAL_LOG_FORMAT(E, format), ##__VA_ARGS__)
src/Main.cpp:111:9: note: in expansion of macro 'ESP_LOGE'
*** [.pio\build\ESP_4096\src\Main.cpp.o] Error 1
src/domoticz.cpp: In function 'String process_messageReceived(String)':
src/domoticz.cpp:98:51: warning: 'typename ArduinoJson6194_F1::enable_if<ArduinoJson6194_F1::is_same<T, char*>::value, const char*>::type ArduinoJson6194_F1::VariantRef::as() const [with T = char*; typename ArduinoJson6194_F1::enable_if<ArduinoJson6194_F1::is_same<T, char*>::value, const char*>::type = const char*]' is deprecated: Replace as<char*>() with as<const char*>() [-Wdeprecated-declarations]
const char *value = kv.value().as<char *>();
In file included from .pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Array/ArrayIterator.hpp:8,
from .pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Array/ArrayRef.hpp:8,
from .pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson.hpp:24,
from .pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson.h:9,
from src/domoticz.cpp:12:
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/VariantRef.hpp:113:7: note: declared here
as() const {
========================================================================================= [FAILED] Took 12.15 seconds =========================================================================================
Thanks, Ron
THBR
ESP32-CAM uploading files
Post by THBR »
Tried to upload the files to the ESP32-cam as described under “First time files upload”, but when I try to compile, Platformio keeps throwing an error. I’am new to Visual Studio Code/PlatformIO and can’t get rid of a error message about not finding “the package with ‘alanswx/ESPAsyncWiFiManager @ ˄0.22’.
That's why I want to upload both bin files (firmware.bin and spiffs.bin) to the ESP32 cam with the esp32 download tool from Espressif.
I can't seem to figure out at which hex addresses the bin files should be placed. Which addresses should I use for this?
ESP32 download.jpg (281.25 KiB) Viewed 4732 times
Kedi
Post by Kedi »
Use
alanswx/ESPAsyncWiFiManager @ ^0.31
THBR
Post by THBR »
Yes, thanks, that problem solved.
But now new errors (deleting en reinstalling the package "framework-arduinoespressif32" without result).
Any idea?
##### Starting script. #######
Compiling .pio\build\ESP_4096\src\Main.cpp.o
Compiling .pio\build\ESP_4096\src\WebServer.cpp.o
Compiling .pio\build\ESP_4096\src\cam.cpp.o
Compiling .pio\build\ESP_4096\src\domoticz.cpp.o
In file included from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal.h:80,
from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:36,
from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFiClient.h:24,
from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/libraries/WiFi/src/WiFi.h:37,
C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/esp32-hal-log.h:159:72: note: in definition of macro 'log_e'
src/cam.cpp: In function 'void initcamera()':
src/cam.cpp:343:12: warning: 'camera_config_t::<unnamed union>::pin_sscb_sda' is deprecated: please use pin_sccb_sda instead [-Wdeprecated-declarations]
config.pin_sscb_sda = SIOD_GPIO_NUM;
In file included from src/cam.cpp:9:
C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/esp32-camera/driver/include/esp_camera.h:123:87: note: declared here
int pin_sscb_sda __attribute__((deprecated("please use pin_sccb_sda instead"))); /*!< GPIO pin for camera SDA line (legacy name) */
src/cam.cpp:344:12: warning: 'camera_config_t::<unnamed union>::pin_sscb_scl' is deprecated: please use pin_sccb_scl instead [-Wdeprecated-declarations]
config.pin_sscb_scl = SIOC_GPIO_NUM;
C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/include/esp32-camera/driver/include/esp_camera.h:127:87: note: declared here
int pin_sscb_scl __attribute__((deprecated("please use pin_sccb_scl instead"))); /*!< GPIO pin for camera SCL line (legacy name) */
In file included from .pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson.hpp:42,
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp: In instantiation of 'static T ArduinoJson::V6215PB2::Converter<T, Enable>::fromJson(ArduinoJson::V6215PB2::JsonVariantConst) [with T = char*; Enable = void]':
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/VariantRefBase.hpp:53:34: required from 'typename ArduinoJson::V6215PB2::detail::enable_if<(! ArduinoJson::V6215PB2::detail::ConverterNeedsWriteableRef<T>::value), T>::type ArduinoJson::V6215PB2::detail::VariantRefBase<TDerived>::as() const [with T = char*; TDerived = ArduinoJson::V6215PB2::JsonVariant; typename ArduinoJson::V6215PB2::detail::enable_if<(! ArduinoJson::V6215PB2::detail::ConverterNeedsWriteableRef<T>::value), T>::type = char*]'
src/domoticz.cpp:98:51: required from here
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:32:20: error: no matching function for call to 'convertFromJson(ArduinoJson::V6215PB2::JsonVariantConst&, char*&)'
convertFromJson(src, result); // Error here? See https://arduinojson.org/v6/unsupported-as/
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:275:13: note: candidate: 'void ArduinoJson::V6215PB2::convertFromJson(ArduinoJson::V6215PB2::JsonVariantConst, String&)' <near match>
inline void convertFromJson(JsonVariantConst src, ::String& dst) {
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:275:13: note: conversion of argument 2 would be ill-formed:
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:32:26: error: cannot bind non-const lvalue reference of type 'String&' to an rvalue of type 'String'
In file included from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:188,
from src/domoticz.h:1,
from src/domoticz.cpp:7:
C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/WString.h:59:9: note: after user-defined conversion: 'String::String(const char*)'
String(const char *cstr = "");
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:291:13: note: candidate: 'void ArduinoJson::V6215PB2::convertFromJson(ArduinoJson::V6215PB2::JsonVariantConst, std::__cxx11::string&)' <near match>
inline void convertFromJson(JsonVariantConst src, std::string& dst) {
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:291:13: note: conversion of argument 2 would be ill-formed:
.pio/libdeps/ESP_4096/ArduinoJson/src/ArduinoJson/Variant/ConverterImpl.hpp:32:26: error: cannot bind non-const lvalue reference of type 'std::__cxx11::string&' {aka 'std::__cxx11::basic_string<char>&'} to an rvalue of type 'std::__cxx11::string' {aka 'std::__cxx11::basic_string<char>'}
In file included from c:\users\theo\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\string:52,
from c:\users\theo\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\stdexcept:39,
from c:\users\theo\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\array:39,
from c:\users\theo\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\tuple:39,
from c:\users\theo\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\functional:54,
from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.h:49,
from C:/Users/Theo/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:196,
c:\users\theo\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\basic_string.h:514:7: note: after user-defined conversion: 'std::__cxx11::basic_string<_CharT, _Traits, _Alloc>::basic_string(const _CharT*, const _Alloc&) [with _CharT = char; _Traits = std::char_traits<char>; _Alloc = std::allocator<char>]'
basic_string(const _CharT* __s, const _Alloc& __a = _Alloc())
*** [.pio\build\ESP_4096\src\domoticz.cpp.o] Error 1
========================================================================================================================== [FAILED] Took 9.60 seconds ==========================================================================================================================
* The terminal process "C:\Users\Theo\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'ESP_4096'" terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Kedi
Post by Kedi »
This is an OLD project, started some 4 years ago. I compiled it at that time. Tried to compile it now and ran into some errors.
Tried different (older) platform ([email protected]) that solved some of the problems, but not all.
The only persons that could possibly help are the 2 git users Hoeby and jvanderzande of which both are still present in this form:
@hoeby and @jvdz
jvdz
Domoticz version: 4.107
Post by jvdz »
I saw the question, but haven't compiled/looked at this myself for a long time now, as we stopped with the development.
Kedi
Post by Kedi »
It looks to me that the partitioning was from the 'default.csv'.
So from that file you could take the addresses. (no guarantee)
Normally you can find that file in:
C:\Users\<username>\AppData\Local\Arduino15\packages\esp32\hardware\esp32\<version>\tools\partitions
THBR
Post by THBR »
Thanks for responding, hoping for a solution, I already purchased the hardware and a printed 3d case.
The contents of the default.csv:
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xe000, 0x2000,
app0, app, ota_0, 0x10000, 0x140000,
app1, app, ota_1, 0x150000,0x140000,
spiffs, data, spiffs, 0x290000,0x160000,
coredump, data, coredump,0x3F0000,0x10000,
So I tried the offset:
firmware.bin 0x10000
spiffs.bin 0x290000
and also
firmware.bin 0x150000
spiffs.bin 0x290000
Both times writing went ok without errors and ended with "is stub and send flash finish"
But both uploads did not result that the camera came in into Wifi AP mode (no ESP Doorbell ssid).
jvdz
Post by jvdz »
Why do you need all of this? When you follow the available wiki the segmentation is part of the steps when using platformio to upload the firmware and data files
Kedi
Post by Kedi »
@jvdz Because it did not compile.
I changed the JSON lib to an old(er) one and then it did compile.
Try in platformio.ini: And be sure to remove the ' ^ '
jvdz
Post by jvdz »
I've made some changes to my local version of the project to make it compile again:
  • replaced SPIFFS for LittleFS as support for SPIFFS is dropped
  • replaced "me-no-dev/ESP Async WebServer@^1.2.3" with "https://github.com/me-no-dev/ESPAsyncWebServer.git" as workaround.
    There seems to be an issue with this for a while now in Platformio.
After that, the source compiled fine, but still need to test loading it to the ESP32CAM.
I also see that there are 24 commits in de Development branch which aren't merged into the Master yet.
Will test my changes first we I have some time later today/tomorrow and commit when working.
jvdz
Post by jvdz »
I can't get it to work at the moment... get a "brown out" when the Wifi is trying to connect and have no idea's left to try to fix that.
Kedi
Post by Kedi »
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
void setup(){
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
Might help, because probably a power issue (on the wifi connect).
jvdz
Post by jvdz »
Seen that one and tried it... :(
THBR
Post by THBR »
Thanks !
I don't know exactly how ("try and error"), but finally I got it working with the settings in the platform.ini:
- platform = [email protected]
- alanswx/ESPAsyncWiFiManager@^0.31.0
- bblanchon/[email protected]
Camera is working now, also added it with succes to Domoticz.
Another question (I am a noob...): when I push the button, a snapshot should be saved in /var/tmp ?
Nothing happens/no files saved in that dir
additonal information:
The push button apparently does not communicate with Domoticz at all. Switching a dummy/virtual switch (in this case with idx 724) also does not work.
Kedi
Post by Kedi »
THBR wrote: Sunday 04 August 2024 12:13 Another question (I am a noob...): when I push the button, a snapshot should be saved in /var/tmp ?
Do you have write rights to /var/tmp ??
THBR
Post by THBR »
Kedi wrote: Monday 05 August 2024 11:52
Yes, I have.
