System Alive Checker question Topic is solved
ilex
Post by ilex »
Hi.
I use System Alive Checker (Ping).
Below example from Domoticz Wiki:
Simple question: is there any way with script or better w json url to change "Sauron" device to other value ?
Why I need that ? My Mikrotik router has a backup LTE ISP uplink with dynamic IP address. I wish to send obtained IP address to domoticz every time it is changed.
Any hint ?
Best regards to all
Domoticz version: 2026.3
Re: System Alive Checker question
Change the value from the web ui and check with F12, section network the API call to modify. It could be that part of the url is base64 encoded
Kedi
Domoticz version: latest
Post by Kedi »
This is the url:
http://192.168.2.xxx:8080/json.htm?type=command&param=pingerupdatenode&idx=<hardware idx>&nodeid=<node ID>&name=<name>&ip=<ip-address>&timeout=5
ilex
Post by ilex »
@Kedi: You have made my day - thx !
"status" : "OK",
"title" : "PingerUpdateNode"
ilex
Post by ilex »
After upgrade of domoticz to Version: 2024.6 (build 16150) it seems to me code is not working any longer. Can someone confirm that ?
BR.
solarboy
Domoticz version: 2024.6
Post by solarboy »
I get lots of false positives with this.
