Please use template to report bugs and problems. Post here your questions when not sure where else to post Only for bugs in the Domoticz application! other problems go in different subforums!
Forum rules
I wish I could. I am trying lol. I am trying to open a https page and read the content. I tried to open a few older applications but it is difficult.
It is quite complicated for a person like me. Could you help by giving me the code to current implementation?
If you contact Gizmocuz on slack he can help implementing the storage feature. He probably needs API info and test data from you as he probably does not have the hardware and then it is difficult to implement.
So if you want this feature please contact him.....
Solaredge via Web update seems to work reasonably fine.
However, the app (on my phone, and on the Solaredge website) works near realtime, while Domoticz updates very slowly (like once every five minutes)
Is the ev charger included as well (in that case I may need to enable it to get it into Domoticz)?
The Energy Dashboard looks fine, but with the Solaredge inline meter and the values from the api, it just looks nice for now, but that's about it for me. For instance I can not set the grid power (from the Solaredge api) to the p1/net in the dashboard settings.
Forgive me for mixing the Solaredge a bit with the Energy Dashboard.
Well, you get a certain amount of API calls a day. (300, which is one call every 5 minutes)
This is probably not limited for their own mobile app.....
Another way (what I did for my Enphase system) is to use a Shelly EM and place a CT clamp on my PV string +.
But if you want to do this as well, remember, that if you have your PV on multiple phases, you need to power the Shelly EM from the SAME phase you put the clamp on. (Also if you have 1 string), otherwise the readings are wrong.
Or you could reverse engineer the app or sniff your switch/router network traffic and see how they call the API (or what browser string they use)
In domoticz, the Solaredge via web API isn't updated anymore since last night.
The solar inverter is working: The solaredge via modbus readout is doing fine, reverse energy measured via p1 meter is doing fine
I am on Beta: Version: 2025.1 (build 16657) running on a raspberry pi
do more users have this error?
has something changed on their API?
On their updated monitoring platform I see no "admin" section anymore (I had it before) where I can see my API code.
The company where I bought the installation from stopped some time ago.
On https://monitoringapi.solaredge.com/sit ... i_key=<key> I can see my details.
Yes, but the hardware shouldn't make domoticz unresponsive and/or crash, so there's also an issue in the hardware driver code.
I have disabled the hardware for now after 2 hangs/crashes.
