Update API solaredge Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hjzwiers
Post by hjzwiers »
I see in the documentation that the API of Solaredge now includes batteries (
https://monitoringapi.solaredge.com/site/XXXX/currentPowerFlow?api_key=XXX
Is it time to update the link in SolarEdge with the PowerFlow settings?
gizmocuz
Re: Update API solaredge
Post by gizmocuz »
That could indeed be interesting. Just poll it at startup and if no batteries are found stop polling this again
Could you add support for this?
hjzwiers
Post by hjzwiers »
I wish I could. I am trying lol. I am trying to open a https page and read the content. I tried to open a few older applications but it is difficult.
It is quite complicated for a person like me. Could you help by giving me the code to current implementation?
gizmocuz
Post by gizmocuz »
You can find all the code of Domoticz on out github page
https://github.com/domoticz/domoticz/blob/development/hardware/SolarEdgeAPI.cpp
gizmocuz
Post by gizmocuz »
Could you send me a message on our slack channel (and also copy the url to this topic) ?
https://join.slack.com/t/domoticz/shared_invite/zt-wo7hrgc3-qIH0EFX_jcBrG2dBSOTRwg
hjzwiers
Post by hjzwiers »
I've check the code but this is much to ambitious undertaking for me .... sorry but I don't see myself doing this
gizmocuz
Post by gizmocuz »
That's why I asked to send me a message on our slack channel
hjzwiers
Post by hjzwiers »
And add it as a feature request? I can do that
Domoticz version: 2024.7
If you contact Gizmocuz on slack he can help implementing the storage feature. He probably needs API info and test data from you as he probably does not have the hardware and then it is difficult to implement.
So if you want this feature please contact him.....
gizmocuz
Post by gizmocuz »
Domoticz SolarEdge integration has been modified to include the storage
eddieb
Post by eddieb »
SolarEdge via modbustcp does not show the battery yet ...
SolarEdge via web works nice and displays the battery
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC with Node-Red and MQTT / SolarEdge SE3500H modbus_tcp / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
jannl
Domoticz version: 2022.2
Post by jannl »
Solaredge via Web update seems to work reasonably fine.
However, the app (on my phone, and on the Solaredge website) works near realtime, while Domoticz updates very slowly (like once every five minutes)
Is the ev charger included as well (in that case I may need to enable it to get it into Domoticz)?
The Energy Dashboard looks fine, but with the Solaredge inline meter and the values from the api, it just looks nice for now, but that's about it for me. For instance I can not set the grid power (from the Solaredge api) to the p1/net in the dashboard settings.
Forgive me for mixing the Solaredge a bit with the Energy Dashboard.
gizmocuz
Post by gizmocuz »
Well, you get a certain amount of API calls a day. (300, which is one call every 5 minutes)
This is probably not limited for their own mobile app.....
Another way (what I did for my Enphase system) is to use a Shelly EM and place a CT clamp on my PV string +.
But if you want to do this as well, remember, that if you have your PV on multiple phases, you need to power the Shelly EM from the SAME phase you put the clamp on. (Also if you have 1 string), otherwise the readings are wrong.
Or you could reverse engineer the app or sniff your switch/router network traffic and see how they call the API (or what browser string they use)
jannl
Post by jannl »
A ok. Didn't know (or remember) the limited api calls.
Verstuurd vanaf mijn SM-G980F met Tapatalk
DomoFlits
Domoticz version: Bld16583
Post by DomoFlits »
In domoticz, the Solaredge via web API isn't updated anymore since last night.
The solar inverter is working: The solaredge via modbus readout is doing fine, reverse energy measured via p1 meter is doing fine
in my logs I see every 5 minutes:
2025-05-04 13:28:18.130 Error: PV installatie: Error getting http data (Equipment details)!
2025-05-04 13:28:18.392 Error: PV installatie: Error getting http data (currentPowerFlow details)!
I am on Beta: Version: 2025.1 (build 16657) running on a raspberry pi
do more users have this error?
has something changed on their API?
On their updated monitoring platform I see no "admin" section anymore (I had it before) where I can see my API code.
The company where I bought the installation from stopped some time ago.
On https://monitoringapi.solaredge.com/sit ... i_key=<key> I can see my details.
madpatrick
Post by madpatrick »
I'm have the same problems.
Worked for year and suddenly it stopped working.
Also the admin sectionis gone in my portal.
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2024.7 -=- Dashticz v3.14b on Tab8" =-
rolfie23
Post by rolfie23 »
madpatrick wrote: Sunday 04 May 2025 13:58 Hi,
Here the same, it also let domoticz crash for some reason. The plugin doesn't use siteid, maybe that's missing?
jannl
Post by jannl »
I would say there are problems with the api at Solaredge. I get update every now and then.
jvdz
Domoticz version: 4.107
Post by jvdz »
Yes, but the hardware shouldn't make domoticz unresponsive and/or crash, so there's also an issue in the hardware driver code.
I have disabled the hardware for now after 2 hangs/crashes.
jannl
Post by jannl »
Never had any problems with de solaredge hardware in Domoticz. So I doubt it is solely the Solaredge plugin.
