RFXCOM RAW Transmit RFY
I’m trying to send a command to my Somfy blind using RFXmngr. Unfortunately the command that I need is not in the list. I would like to send an ‘up/down > 2 sec’ command. The command most simular to this command is the ‘up/down > 5 sec’ command. Would it be possible for someone to translate the ‘up/down > 5 sec’ command to a ‘up/down > 2 sec’ command in a raw transmit file?
Would like to know if something like this is possible, if more information needed: please ask!
Many thanks in advance.
- updown5sec.png (78.75 KiB) Viewed 7311 times
b_weijenberg
- Target OS: -
Re: RFXCOM RAW Transmit RFY
It is not possible to transmit a RAW RFY command.
The available RFY commands are pre-programmed in the RFX firmware and a new command would need a firmware update.
Why do you need an ‘up/down > 2 sec’ command?
Maybe better to contact RFXCOM support?
RFX-433, RFX-433EMC, RFX-868
Thanks for you answer! I would like to use the command to set my Somfy RTS Motor from US to EU mode (see image below). By pressing the 'up/down > 5 sec' command, the motor already goes to EU mode, but unfortunately this setting will only be saved when confirming with an 'up/down > 2 sec' command, otherwise the motor will return to US mode after ~1,5 minute. EDIT: I just noted that there are various manuals on the internet to switch between the mode. Either confirm it with 'up/down > 2 sec' or confirm it with 'down/my > 2 sec' command, but both commands are not available.b_weijenberg wrote: Wednesday 15 May 2024 10:53 It is not possible to transmit a RAW RFY command.
Ofcourse I could buy a regular Somfy remote, but since I can program all other things with the RFXcom, I would really prefer that way. Do you have any experience with RFXcom support?
- Schermafbeelding 2024-05-15 170807.png (75.92 KiB) Viewed 7261 times
BartSr
- Domoticz version: V2024.7
to my knowledge you need a somfy remote to program upper and lower limit as well as the 'my' position.
I can't recall right now but for some reason you need during set-up to press both up and down together which is impossible with rfxcom
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
b_weijenberg
- Target OS: -
Up-Down is possible with RFXCOM, see the screen above!
@tomtw: I'm RFXCOM support
That's awesome! The RFXcom is working perfectly. I have programmed an Up and Down position and have integrated this into Home Assistant with ease. My problem with the US mode - where it is currently in - is that I cannot send a short command to tilt the blind just a degree or two (see image below).b_weijenberg wrote: Wednesday 15 May 2024 21:15 Up-Down is possible with RFXCOM, see the screen above!
@tomtw: I'm RFXCOM support![]()
When I send a short 'UP or Down < 0,5 sec' command in US mode, the blinds will go to the open or close position. Only when I send an 'Up or Down'command for > 2 seconds, the blinds will start to tilt. Tilting like this will always be like 10 or more degrees.
This is why I would like to set the somfy motor to EU mode, and like I said before: When I send an UP/DOWN > 5 second command, the somfy motor is already set to EU mode and works perfectly with Home Assistant! The only problem is that I cannot save the mode into the somfy motor by sending an MY/Down > 2 sec or Up/Down > 2 sec command.
Would it be possible to fix this or can we figure out a work around?
- Naamloos.png (5.74 KiB) Viewed 7232 times
b_weijenberg
- Target OS: -
BartSr
@b_weijenberg
apologize for my wrong statement
-Bart
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Had contact with RFXcom support today and they almost instantly updated the software and added the needed command!! Awesome! Programming, controlling and switching between EU/US mode for Somfy RTS is now possible all without the need of a separate Somfy remote control. Thanks!
b_weijenberg
- Target OS: -
The latest RFX433XL firmware version 2032 and RFXmngr 19.0.0.57 support the down+stop/My > 2 seconds command.
The files are available on the RFXCOM Downloads page
