switch tab
goblin
Domoticz version: 2023.1
switch tab
Post by goblin »
hello,
i have tried to find this suggestion in this topic but haven't found it.
I have too many switches in the switch tab and temperature devices in the tep tab.
it is possible to copy a few to the dashboard tab but then this tab would turn into a unreadable tab. with to many entries.
So it would be nice to have e.g. multiple "switch" tabs. Then i can e.g. have one switch tab with all light switches (output switch) and another with e.g. all dummies or Pir (input switches). Also multiple "temp" tab would useful to separate e.g. room temperature from outside temperature/boiler/heating radiators/airco etc.
just an idea which could make life easier.
dankie / thanks
goblin
Re: switch tab
Post by goblin »
i just found this topic
Re: Ability to group some devices with a dedicated view.
So will dive into templates.
regards
Domoticz version: 2025.1
Re: switch tab
The tabs are pretty much hardcoded in the Domoticz webserver code (Javascript). So you have to change that a lot to have it get more flexible.
Another option for you is to use rooms so you can easily filter the switches tab per room (or function, whatever name you use for a room) and additional you can use floorplan where you can make multiple floorplans (or function groups).
https://www.domoticz.com/wiki/Floorplans
azonneveld
Domoticz version: 2024.4
Re: switch tab
Post by azonneveld »
Perhaps the mobile dashboard works for you, this makes a list from your dashboard.
Goto:settings and change the user interface to Mobile.
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
HansieNL
Re: switch tab
Post by HansieNL »
Maybe Dashticz is an option?
You can create your own dashboard look and mix different devices on same page.
https://github.com/Dashticz
Blah blah blah
HvdW
Domoticz version: 2023.2
Re: switch tab
Post by HvdW »
What about a custom menu?
Bugs bug me.
