Version 3.12 - Bug
Doudy
Version 3.12 - Bug
Post by Doudy »
Good morning,
I just installed version 3.12 Master
Issue :
I only have access to the first 'Weather' page
The different tabs are inaccessible
Page 1 and 2 'Weather + Home Info' are on the same page when starting !
I did a git checkout . + git pull
I haven't modified any files in dashticz!
Page 1
Page2
Lokonli
Re: Version 3.12 - Bug
Post by Lokonli »
There is a small bug in master 3.12:
If you have dial that uses a domoticz device that doesn't exist then Dashticz will stop rendering additional blocks.
It has been fixed in the beta branch.
or, try to locate the unknown device.
Doudy
Post by Doudy »
I found the intruder
How to install the beta branch?
HansieNL
Post by HansieNL »
If you did install via Terminal you can change branch by following commands in the Dashticz main folder:
git checkout beta
git pull
Otherwise you have to download the beta.zip and unpack in Dashticz folder. You can cleanup Dashticz folder before unpack. BACKUP CUSTOM FOLDER
Blah blah blah
Doudy
Post by Doudy »
