setcolor results in openurl 0.0.0.0:80 [solved with workarround]
ravaoo
Domoticz version: 2024-7
Re: setcolor results in openurl 0.0.0.0:80
Post by ravaoo »
Kedi wrote: Monday 25 March 2024 11:40 What's the output of
sudo docker ps -a
when you ssh into your NAS
it should be something like
0f788fe90201   domoticz/domoticz:latest             "docker-entrypoint.s…"   45 hours ago    Up 45 hours             443/tcp, 0.0.0.0:8080->8080/tcp, :::8080->8080/tcp
Special IP 0.0.0.0:<port> should be present.
Output of
73529c86a201 domoticz/domoticz:latest "docker-entrypoint.s…" 30 seconds ago Up 28 seconds 443/tcp, 8080/tcp, 0.0.0.0:8082->80/tcp, :::8082->80/tcp domoticz
Running latest BETA on on Docker (Container Manager) in Synology NAS using zwave_js_ui with mqtt. Getting started with homebridge.
Living in an automated house is a survival but it is worth it
Domoticz version: 2026.3
You could try to add 127.0.0.* in the Domoticz trusted network settings.
Perhaps also add localhost.
Also be sure you do not have spaces in the trusted network list of IP's
Kedi
Domoticz version: latest
Post by Kedi »
What docker version are you running?
sudo docker --version
I have version 20 and version 25 running. An upgrade from version 25 to 26 gave some problems with my Raspberry Pi4B (64 bits), so I reverted back to 25.
Kedi
Post by Kedi »
I ran netstat -tulpn inside the container and I got this response.
Perhaps you could check if it is somewhat the same.
If you do not have netstat available, install it inside the container with:
apt-get install net-tools
ravaoo
Post by ravaoo »
Kedi wrote: Monday 25 March 2024 18:38 What docker version are you running?
i run version : Docker version 20.10.23, build 876964a (is part of container manager on synology nas)
ravaoo
Post by ravaoo »
I cant install net-tools. Maybe this is related to my problem
Kedi
Post by Kedi »
You should be able to install net-tools inside the container, because I use the same, and it was no problem with my container.
Search for: docker bash into container to know how. e.g. sudo docker exec -it <mycontainer> bash
I also have in one of my setups Domoticz running in Docker on my Synology NAS.
Again, what are your trusted network settings? If not correct you get the same error....
ravaoo
Post by ravaoo »
waltervl wrote: Tuesday 26 March 2024 16:02 Again, what are your trusted network settings? If not correct you get the same error....
I tried the folowing settings:
172.20.0.*
0.0.0.0
172.20.0.*,127.0.0.*
127.0.0.*
172.20.0.*,127.0.0.*,0.0.0.0,local
local
local,LOCAL
172.20.0.*,127.0.0.*,0.0.0.0,local,LOCAL
also <blank>
All with the same error
ravaoo
Post by ravaoo »
I don't understand wat is the problem but found a way around it by using the Hue API.
	domoticz.openURL({
        url = 'https://10.1.2.52/api/xxx/lights/17/state',
				method = 'PUT',
				postData = { on = true, sat = 254 , bri = 254 , hue = 1000 },
				callback = 'return',
I now can change color of my lamp. I made a color tabel to choose the right hue value.
