lua error returned: 32256
mistreg94
Post by mistreg94 »
Hello everybody,
I can not use the command line " os.execute" in a lua script.
I get the following error:
Error: Error executing script command (/home/pi/domoticz/scripts/lua/script_device_hyperion.lua). returned: 32256
I created a virtual hardware "Equipement Virtuel" :
I add a new "Manual Light/Switch" on my hardware "Equipement Virtuel" :
I attached the script (script:///home/pi/domoticz/scripts/lua/script_device_hyperion.lua) on my switch Hyperion :
Here are the contents of my folder "lua" :
Here is the code of my script "script_device_hyperion.lua" :
if (devicechanged['Hyperion'] == 'Off') then
      commandArray['Lumière Salon']='On'
      os.execute ('/home/pi/domoticz/scripts/lua/script-ssh_reboot-hyperion.sh')
Here is the code of my script "script-ssh_reboot-hyperion.sh" :
#!/bin/bash
ssh root:[email protected] //storage/reboot_hyperion.sh
When I run the script "script-ssh_reboot-hyperion.sh" in a terminal, it works well :
When I press my button "Hyperion," the light of my living room lights ("Lumière Salon").
But my script "script-ssh_reboot-hyperion.sh" is not executes and I get the following logs:
Can you help me ???
Thank you.
misterg94
raspberry B+ / raspbian wheezy / domoticz V2.2151 / RFXtrx433E & Aeon Z-Stick S2
raspberry B+ / openelec with Hyperion / Lightberry
mistreg94
Re: lua error returned: 32256
Post by mistreg94 »
I found my problem!
Domoticz uses "root" to launch scripts.
I had only generated an ssh key for "pi".
Here are the actions that I realized :
1/ I chose a new password for"root"
pi@domoticzpi $ sudo passwd root
2/ I log in "root" :
3/ I generate a new ssh key :
root@domoticzpi: ssh-keygen -t rsa
4/ I export this new key on my other server
Further, in my code, the ' were not good :
mistreg94
Post by mistreg94 »
I deleted "script-ssh_reboot-hyperion.sh" and I modified "script_device_hyperion.lua" like this :
      os.execute ('ssh root:[email protected] //storage/reboot_hyperion.sh')
problem solved
ArturK
lua error returned: 32256 - solution
Post by ArturK »
My simple solution for error 32256 is to change permission rights to the script *.sh. You don't have rights, change it to 0777 (rwxrwxrwx) and that's all.
Raspberry Pi 2B, Logitech Harmony Hub, Z-Stick GEN 5.
ErikAtSpijk
Domoticz version: 4.10717
Post by ErikAtSpijk »
Thanks, had the excact same two problems
