Log2Ram uses max amount assigned memory
njlammerts
Domoticz version: 2022.2
Post by njlammerts »
On my Pi-4 + Domoticz on SD card i use Log2Ram as a cache for log files protecting to much read/write to this SD card. When i first started with Pi and Domoticz I had crashes after several months "blowing up" my SD due to much read/write actions.
Since the use of Log2Ram I had not have any SD card problems anymore. I make a SD card copy once a year to a new SD card to prevent card damage.
Since some time I notice on 1 Pi-4/Domoticz configuration that the reserved Log2Ram memory is at 100% use after 2-5 days. Below picture is after 2 day of cleaning up /var/log/ of all log files and do a reboot (first stopped Domoticz and Log2Ram service) On other Pi/Domoticz (I have 4 in total) the used memory is 17, 70, 11 % and the last reboot was over more than a month ago.
Scherm­afbeelding 2024-03-07 om 10.26.41.png (142.94 KiB) Viewed 3369 times
On the "problem" Pi I have about 400 Zigbee devices listed (125 used) and some errors in the log. I am in the proces of setting up a new Pi4 with external 2.5" SSD with and installing Mosquito, Zigbee2MQTT and Domoticz on/with Docker, managed by Portainer (not successful until now)
I am looking for a "quick fix" by resetting the logfile's once a week to prevent the memory to run full.
Has anyone an idea on how to clean up/ free up the reserved Log2Ram memory?
Kedi
Domoticz version: latest
Re: Log2Ram uses max amount assigned memory
Post by Kedi »
Do a
ls -al /var/log/
and look for what is taking up all the space, and take action on that file(s) by logrotate.
And the same of course for any subdirectory.
njlammerts
Below the result
Scherm­afbeelding 2024-03-07 om 12.13.48.png (166.07 KiB) Viewed 3356 times
Scherm­afbeelding 2024-03-07 om 12.19.13.png (152.95 KiB) Viewed 3356 times
Kedi
Post by Kedi »
So 'daemon.log' and 'syslog' are too big.
It looks like you have logrotate installed, check with
sudo systemctl status logrotate.service
sudo systemctl status logrotate.timer
Both should be enabled.
Also look in the dir '/var/log/journal' there might be some big files too.
In '/etc/logrotate.d' there should be a file called 'rsyslog' or 'syslog'
This is my file:
/var/log/syslog
/var/log/auth.log
    rotate 1
    daily
    missingok
    notifempty
    compress
    postrotate
        /usr/lib/rsyslog/rsyslog-rotate
    endscript
/var/log/mail.info
/var/log/mail.warn
/var/log/mail.err
/var/log/mail.log
/var/log/msmtp.log
/var/log/daemon.log
/var/log/kern.log
/var/log/user.log
/var/log/lpr.log
/var/log/cron.log
/var/log/debug
/var/log/messages
    rotate 1
    weekly
    missingok
    notifempty
    compress
    sharedscripts
    postrotate
    endscript
Most important parts are 'rotate 1' and 'daily / weekly'
With that you control how many rotated files are created and if it is done daily or weekly.
Kedi
Post by Kedi »
If the files in the 'journal' directory are too big you can change the journal settings in the file '/etc/systemd/journald.conf
Change these settings by editing and removing the '#' as an example:
SystemMaxUse=100M
SystemMaxFileSize=100M
MaxRetentionSec=1week
After the conf change restart the journal service with.
sudo service systemd-journald restart
njlammerts
hereby the results of commands, including var/log/journal result
Scherm­afbeelding 2024-03-07 om 16.53.29.png (171.77 KiB) Viewed 3334 times
content of /etc/logrotate.d/rsyslog
/var/log/syslog
/var/log/mail.info
/var/log/mail.warn
/var/log/mail.err
/var/log/mail.log
/var/log/daemon.log
/var/log/kern.log
/var/log/auth.log
/var/log/user.log
/var/log/lpr.log
/var/log/cron.log
/var/log/debug
/var/log/messages
rotate 4
weekly
missingok
notifempty
compress
delaycompress
sharedscripts
postrotate
endscript
Kedi
Post by Kedi »
You missed output from
And to see the size of files you should do
ls -al /var/log/journal
Kedi
Post by Kedi »
change rotate from 4 to 1 and weekly to daily or use my '/etc/logrotate.d/rsyslog'
njlammerts
i Changend 4 to 1 and weekly to daily
requested output:
Scherm­afbeelding 2024-03-07 om 20.12.03.png (189.92 KiB) Viewed 3312 times
Kedi
Post by Kedi »
Logrotate.timer is enabled, so logrotate will work.
Now you have to wait until logrotate is run, normally that will be somewhere after midnight.
Your content of /var/log/journal looks good,but depending what is in the dir f95f.........
You could now manually delete those big files and reboot, just to be sure that the /var/log will not reach full before logrotate runs.
njlammerts
in the f95f......... are the following files
system.journal
user-1000.journal
Kedi
Post by Kedi »
Again it is about how big they are (the '-al' does that).
You could use the settings I suggested.
SystemMaxUse=100M
Did the logrotate help?
njlammerts
All the Log2Ram reserved memory is full the f95f..... directory is filled with *.journal~ files
I changed the weekly to daily and rotate from 4 to 1
below the last result, while 12h ago the mem use was 50%
PS: i removed all the files in the f95f... directory and now the mem use is 50% again (df -h)
pi@Pi245:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 29G 2.9G 25G 11% /
devtmpfs 667M 0 667M 0% /dev
tmpfs 925M 0 925M 0% /dev/shm
tmpfs 370M 39M 332M 11% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
/dev/mmcblk0p1 255M 52M 204M 21% /boot
log2ram 192M 192M 0 100% /var/log
tmpfs 185M 0 185M 0% /run/user/1000
pi@Pi245:~ $ cd /var/log/journal
pi@Pi245:/var/log/journal $ ls
f95f24a098d047ecb6f4402309e1d1e8
pi@Pi245:/var/log/journal/f95f24a098d047ecb6f4402309e1d1e8 $ ls
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
system@d2ba4039894c4ce485f090f39d3dbe09-00000000000018f5-000613166ca30997.journal
system@d2ba4039894c4ce485f090f39d3dbe09-0000000000019709-0006131883f5026c.journal
system.journal
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
[email protected]~
user-1000@1dd7ffd0a098403abbf4b80e33b87cf9-0000000000001679-00061316277fedc9.journa
Kedi
Post by Kedi »
Again just a 'ls' command does not show file size, only a 'ls -al' command shows the filesize and date.
Put long data in a spoiler tag.
Did you change the changes I proposed in the '/etc/systemd/journald.conf' file?
and do a
 sudo journalctl --disk-usage
Then you can see how much space is used.
Before a reboot you could also clean dir: /var/hdd.log/journal because otherwise that dir is copied to /var/log/journal at every reboot.
njlammerts
started this morning with 50% in use and now, 4h later it has 74% in use
pi@Pi245:/var/log/journal/f95f24a098d047ecb6f4402309e1d1e8 $ ls -al
total 32768
drwxr-sr-x 2 root systemd-journal 80 Mar 8 09:43 .
drwxr-sr-x 3 root systemd-journal 60 Feb 23 14:17 ..
-rw-r----- 1 root systemd-journal 8388608 Mar 8 12:17 system.journal
-rw-r-----+ 1 root systemd-journal 25165824 Mar 8 13:00 user-1000.journal
also cleaned /var/hdd.log/journal/f95f24a098d047ecb6f4402309e1d1e8
below (had already changed it) setting of /etc/systemd/journald.conf
This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2.1 of the License, or
# (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See journald.conf(5) for details.
[Journal]
#Storage=auto
#Compress=yes
#Seal=yes
#SplitMode=uid
#SyncIntervalSec=5m
#RateLimitIntervalSec=30s
#RateLimitBurst=10000
SystemMaxUse=100M
#SystemKeepFree=
#SystemMaxFiles=100
#RuntimeMaxUse=
#RuntimeKeepFree=
#RuntimeMaxFileSize=
#RuntimeMaxFiles=100
#MaxFileSec=1month
#ForwardToSyslog=yes
#ForwardToKMsg=no
#ForwardToConsole=no
#ForwardToWall=yes
#TTYPath=/dev/console
#MaxLevelStore=debug
#MaxLevelSyslog=debug
#MaxLevelKMsg=notice
#MaxLevelConsole=info
#MaxLevelWall=emerg
#LineMax=48K
#ReadKMsg=yes
#Audit=no
Kedi
Post by Kedi »
Find which file(s) grow the fastest.
See which are currently the biggest by
sudo du -h /var/log
It can't be that difficult to find the file(s) that grow fast and should be corrected by some sort.
Did the logrotate run and are the files daemon.log and syslog now small?
njlammerts
This was at +- 13:00h. After ls -la I did a rm *.* in this directory, so it was empty
logrotatie should run this night, I check tomorrow
pi@Pi245:/var/hdd.log/journal/f95f24a098d047ecb6f4402309e1d1e8 $ ls -la
total 32820
drwxr-sr-x+ 2 root systemd-journal 45056 Mar 8 09:43 .
drwxr-sr-x+ 3 root systemd-journal 4096 Feb 23 14:17 ..
-rw-r-----+ 1 root systemd-journal 8388608 Mar 8 13:09 system.journal
-rw-r-----+ 1 root systemd-journal 25165824 Mar 8 13:09 user-1000.journal
below at 15:45h
pi@Pi245:/var/log/journal/f95f24a098d047ecb6f4402309e1d1e8 $ ls -la
total 57344
drwxr-sr-x+ 2 root systemd-journal 120 Mar 8 13:09 .
drwxr-sr-x+ 3 root systemd-journal 60 Feb 23 14:17 ..
-rw-r----- 1 root systemd-journal 8388608 Mar 8 13:09 [email protected]~
-rw-r-----+ 1 root systemd-journal 8388608 Mar 8 15:17 system.journal
-rw-r----- 1 root systemd-journal 25165824 Mar 8 13:09 [email protected]~
-rw-r-----+ 1 root systemd-journal 16777216 Mar 8 15:38 user-1000.journal
deamon and syslog are not present. it seems files in f95f..... are the ones growing now
pi@Pi245:/var/log $ ls -la
total 472
drwxr-xr-x 7 root root 240 Mar 8 13:37 .
drwxr-xr-x 12 root root 4096 May 28 2023 ..
drwxr-xr-x 2 root root 220 Feb 23 14:17 apt
-rw-rw---- 1 root utmp 0 Mar 8 09:36 btmp
-rw-r----- 1 root adm 947 Mar 8 13:09 debug
-rw-r--r-- 1 root root 2664 May 28 2023 faillog
drwxr-sr-x+ 3 root systemd-journal 60 Feb 23 14:17 journal
-rw-rw-r-- 1 root utmp 292292 Mar 8 13:10 lastlog
drwxr-xr-x 2 mosquitto root 60 Mar 4 13:41 mosquitto
drwx------ 2 root root 40 May 3 2023 private
drwxr-xr-x 3 root root 60 Feb 23 14:17 runit
-rw-rw-r-- 1 root utmp 173952 Mar 8 13:10 wtmp
jvdz
Domoticz version: 4.107
Post by jvdz »
Here is a nice webpage that tells you what can be done with the journals. did you perform the command suggested by:
Kedi wrote: Friday 08 March 2024 11:45 Did you change the changes I proposed in the '/etc/systemd/journald.conf' file?
and do a
CODE: SELECT ALL
anyways, look at the linked page and do some checking or even set a max for the journals.
njlammerts
sudo nano /etc/systemd/journald.conf
# This file is part of systemd.
[Journal]
#Storage=auto
#Compress=yes
#Seal=yes
#SplitMode=uid
#SyncIntervalSec=5m
SystemMaxUse=100M
#SystemKeepFree=
#SystemMaxFiles=100
#RuntimeMaxUse=
#RuntimeKeepFree=
#MaxFileSec=1month
#ForwardToKMsg=no
#ForwardToWall=yes
#MaxLevelWall=emerg
#LineMax=48K
#ReadKMsg=yes
#Audit=no
pi@Pi245:~ $ sudo journalctl --disk-usage
Archived and active journals take up 96.0M in the file system.
pi@Pi245:~ $ journalctl --verify
2c9008: Data object references invalid entry at 35207f8
File corruption detected at /var/log/journal/f95f24a098d047ecb6f4402309e1d1e8/user-1000.journal:3520560 (of 58720256 bytes, 94%).
FAIL: /var/log/journal/f95f24a098d047ecb6f4402309e1d1e8/user-1000.journal (Bad message)
PASS: /var/log/journal/f95f24a098d047ecb6f4402309e1d1e8/system.journal
pi@Pi245:~ $
Kedi
Post by Kedi »
Do a
sudo systemctl stop systemd-journald.service
Remove the journal files (don't remove the journal dir),
Perhaps lower the 100M in the /etc/systemd/journald.conf to 50M and do
sudo systemctl start systemd-journald.service
Did the logrotate do its job?
