District warming
remko2000
District warming
I managed to read all the data from my Kamstrup 601. I now see, among other things, the total consumption in GJ. However, I also want to see what my daily consumption is. What is the simplest way to add this to domoticz with an extra dummy sensor?
- Domoticz version: 2025.1
Re: District warming
If you use the proper Domoticz device you should see your daily consumption already.
What device do you use to monitor the heating?
Yes, that is a bummer... They instruct to make custom sensors instead of counters for Heating GJ.
Better try to have them change that.
Can you post a couple of JSON messages from your meter trough
Lets see if we can make up something.
http://ip_address_gateway:82/kamst-ir/api/readDomoticz running on Udoo X86 (on Ubuntu)
remko2000
yes that is exactly the problem. But isn't it possible to work around this with, for example, some kind of script that passes the volume of the current day to a separate day counter?
I am wondering what data this sensor creates. So that is why I asked for some sample jsons from you.
The most interesting value is heat_energy. Is that an increasing value over days or is it reset to 0 every day?
remko2000
The rest api gives me this:
I think my kamstrup gives me every 900 sec a total of 'heat energy'{"mac_address":"C0_49_EF_CE_E6_C4","gateway_model":"connectix_kamst-ir_gateway_v1.0","startup_time":"2024-01-27T19:05:12Z","firmware_running":"2024011002","firmware_available":"2024011002","firmware_update_available":"false","wifi_rssi":"-48","mqtt_configured":"false","heat_energy":"210.310","power":"0.000","temp1":"59.16","temp2":"51.24","tempdiff":"7.92","flow":"0.00","volume":"1491.420","minflow_m":"0.00","maxflow_m":"441.00","minflowdate_m":"240109.00","maxflowdate_m":"240109.00","minpower_m":"0.00","maxpower_m":"18.10","avgtemp2_m":"42.00","minpowerdate_m":"240101.00","maxpowerdate_m":"240109.00","minflow_y":"0.00","maxflow_y":"441.00","minflowdate_y":"240109.00","maxflowdate_y":"240109.00","minpower_y":"0.00","maxpower_y":"18.10","avgtemp1_y":"18.10","avgtemp2_y":"42.00","minpowerdate_y":"240101.00","maxpowerdate_y":"240109.00","temp1xm3":"109199.00","temp2xm3":"57580.00","infoevent":"1.00","hourcounter":"116625.00","power_act":""}
Now the issue is, what does "heat_energy":"210.310" mean? Is it the Energy used for today or the total Energy value from when this meter is running? Similar like your electricity counter in your house.
So if tomorrow it shows for example "heat_energy":"210.710" It means you have used 210.710-210.310=0.400 GJ today. Then we can use this value for a counter.
If it tomorrow shows "heat_energy":"10.710" it means it is reset at night and you need scripting to get something done here.
remko2000
210.310 is the total energy.
This is right.So if tomorrow it shows for example "heat_energy":"210.710" It means you have used 210.710-210.310=0.400 GJ today. Then we can use this value for a counter.
Ah OK that seems promising
Then you could make a Dummy Counter named Heating (or what you wish) see also https://www.domoticz.com/wiki/Dummy_for ... es#Counter
After creation, press on Edit and make it a Custom Counter (type = Counter)
Value Quantity: Heating Energy
Value Units: GJ
Counter divider: 1000 (this is important).
Add in your Lua parser script kamstrup.lua in /domoticz/scripts/lua_parsers the following. It could be that the multiply 1000 line gives an error as the value is a string and perhaps not recognized as a fractal. Please report back if it gives an error.
First value could be high as it could report complete history. you can delete this high value the next day (shift+ mouse click on value in the Graph) and then you have normal values.
When everything works well you can delete the custom sensor and the lua code that fills this custom sensor.
Value Units: GJ
local idx = [IDX of new Counter]
local heat_energy = domoticz_applyJsonPath(request['content'], '.heat_energy')
heat_energy = heat_energy * 1000
domoticz_updateDevice(idx, '' , heat_energy)When everything works well you can delete the custom sensor and the lua code that fills this custom sensor.
remko2000
Thx
what I have now
IDX 251 is called 'heat_energy' (and gives 210,31GJ)
IDX 263 is my new dummy, zie screenshot
My code (in events, lua, type 'all'):
I get an error:
' 2024-01-31 16:48:46.011 Error: EventSystem: in Dagtellerwarmte: [string "local idx = 263 ..."]:2: attempt to index a nil value (global 'request')'
what I have now
local idx = 263
domoticz_updateDevice(idx, '251' , heat_energy)' 2024-01-31 16:48:46.011 Error: EventSystem: in Dagtellerwarmte: [string "local idx = 263 ..."]:2: attempt to index a nil value (global 'request')'
- Schermafbeelding 2024-01-31 om 16.45.30.png (52.91 KiB) Viewed 3612 times
remko2000 wrote: Wednesday 31 January 2024 16:49 Thx
what I have now
My code (in events, lua, type 'all'):I get an error:Code: Select all
local idx = 263 local heat_energy = domoticz_applyJsonPath(request['content'], '.heat_energy') heat_energy = heat_energy * 1000 domoticz_updateDevice(idx, '251' , heat_energy)
domoticz_updateDevice(idx, '251' , heat_energy)Code: Select all
domoticz_updateDevice(idx, '' , heat_energy)Domoticz running on Udoo X86 (on Ubuntu)
Beside my previous remark. You should not create a new script!!!
You should modify the Lua parser script kamstrup.lua in /domoticz/scripts/lua_parsers that you created according this instruction: https://haprofs.com/kamstrup-multical-s ... -domoticz/
remko2000
me wrong.
I changed it. Still error:
'2024-01-31 17:02:50.182 Error: EventSystem: in Dagtellerwarmte: [string "local idx = 263 ..."]:2: attempt to index a nil value (global 'request')'
Is LUA by events, type ' lua', type ' All' ......correct?
waltervl wrote: Wednesday 31 January 2024 17:03 Beside my previous remark. You should not create a new script!!!
remko2000
sorry.
I edit the script kamstrup.lua and add your script at the bottom. Now I get indeed:
so far so good.....
so far so good.....
- Schermafbeelding 2024-01-31 om 17.09.31.png (53.63 KiB) Viewed 3589 times
Lets let it run for at least 2 days.
So after 1 day, do you see some usage graphs in the log page now? Device page showing some normal results?
connectix
Hi Walter!waltervl wrote: Wednesday 31 January 2024 16:21 Ah OK that seems promising
Value Units: GJ
First value could be high as it could report complete history. you can delete this high value the next day (shift+ mouse click on value in the Graph) and then you have normal values.Code: Select all
local idx = [IDX of new Counter] local heat_energy = domoticz_applyJsonPath(request['content'], '.heat_energy') heat_energy = heat_energy * 1000 domoticz_updateDevice(idx, '' , heat_energy)
Thanks for the script adjustments. I updated the instruction for the Kamstrup Multical for Domoticz so other users can benefit from it too.
Keep up the good work!
Greetings, Roel
