Remotely send Device not found! after update
Andrex
Post by Andrex »
I've updated (to the latest version: Version: 2024.3 Build Hash: 3503953dd) the master and the slave Domoticz, but now when I switch something on the slave, on the master I see the error:
I haven't touched the 2 instances in years.
What could it be?
Domoticz version: 2025.1
Re: Remotely send Device not found! after update
Better check this discussion viewtopic.php?f=6&t=41411
Andrex
Post by Andrex »
waltervl wrote: Friday 26 January 2024 9:38 Better check this discussion viewtopic.php?f=6&t=41411
I've solved it removing the remote server from the slave domoticz, adding it back again (updated the password) and it's working again.
Andrex wrote: Friday 26 January 2024 10:01
As indicated in that other topic and for other users coming to this topic:
That's not the solution. You probably did not check if you got new devices. When you delete this, sure you get new devices... but lost all history as well
