Remotely send Device not found! after update
Andrex
Post by Andrex »
I've updated (to the latest version: Version: 2024.3 Build Hash: 3503953dd) the master and the slave Domoticz, but now when I switch something on the slave, on the master I see the error:
I haven't touched the 2 instances in years.
What could it be?
Domoticz version: 2025.1
Re: Remotely send Device not found! after update
Better check this discussion viewtopic.php?f=6&t=41411
Andrex
Post by Andrex »
waltervl wrote: Friday 26 January 2024 9:38 Better check this discussion viewtopic.php?f=6&t=41411
I've solved it removing the remote server from the slave domoticz, adding it back again (updated the password) and it's working again.
Andrex wrote: Friday 26 January 2024 10:01
As indicated in that other topic and for other users coming to this topic:
That's not the solution. You probably did not check if you got new devices. When you delete this, sure you get new devices... but lost all history as well
Users browsing this forum: RNEE and 1 guest
