Christmas light by program
ssk17051980
Domoticz version: 2023.2
Post by ssk17051980 »
I keep trying to make a script even with the help of chat-open-ai, but without success.
my script must turn on a switch, with idx=x, in the period 01.12 - 05.01, for a period of 8 hours, IF another switch with idx=y, is ON.
it is about Christmas lights, and idx=y is a switch that is ON when the sun goes down.
Does anyone have something like this already done and working?
Thank you
willemd
Domoticz version: 2026.3
Re: Christmas light by program
Post by willemd »
Not sure if this timer works, please go ahead and test it.
Alternatively you just could use the "at sunrise" or "at sunset" trigger, then you don't need to check the y switch.
local idxSunDownSwitch=y
local idxLightsSwitch=x
		timer {
		    'every minute on 01/12-05/01',
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'christmas light',
	execute = function(domoticz, timer)
		domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
		if domoticz.devices(idxSunDownSwitch).state=='ON' then
		    if domoticz.devices(idxLightsSwitch).state=='OFF' then
		       domoticz.devices(idxLightsSwitch).switchOn()
		    if domoticz.devices(idxLightsSwitch).state=='ON' then
		       domoticz.devices(idxLightsSwitch).switchOff()
gizmocuz
Post by gizmocuz »
Indded, why not add a timer to your Cristmas light to go on 30 minutes before sunset ?
ssk17051980
willemd wrote: Tuesday 02 January 2024 19:09 Not sure if this timer works, please go ahead and test it.
		timer {
	logging = {
gone test :D
thx
ssk17051980
gizmocuz wrote: Wednesday 03 January 2024 8:49 Indded, why not add a timer to your Cristmas light to go on 30 minutes before sunset ?
i want to be ON in a specific interval
willemd
Post by willemd »
Exactly, that's what he meant: go ON xx minutes before or after sunset, go OFF xx minutes before or after sunrise.
Reading the dzVents documentation will help
willemd wrote: Wednesday 03 January 2024 13:53 Exactly, that's what he meant: go ON xx minutes before or after sunset, go OFF xx minutes before or after sunrise.
You can do this with the normal timer function/button too, no need to program something.
ssk17051980
local idxSunDownSwitch = 267  --indicate the sunrise and sunset /apus (ON/OFF)
local idxLightsSwitch = 23    -- the switch that i want to control (ON/OFF)
        timer = {
            'every minute on 12/01-01/05',
    logging = {
        local sunDownSwitch = domoticz.devices(idxSunDownSwitch)
        local lightsSwitch = domoticz.devices(idxLightsSwitch)
        if sunDownSwitch.state == 'ON' then
            if lightsSwitch.state == 'OFF' then
                lightsSwitch.switchOn()
            if lightsSwitch.state == 'ON' then
                lightsSwitch.switchOff()
not working
willemd
Post by willemd »
If you want help you need to provide some more feedback and info.
I tested the timer trigger and see my script is launched every minute, so that is not the problem.
Is yours launched as well? Is it activated?
Any error messages?
Any info in the log file?
Did you add debug info so that it is shown in the logfile?
ssk17051980
it's working in this form.
I have to change the interval now.
1 Dec - 10 January
        timer = { 'daily' },
        devices = { 267 } -- Se activează și la schimbările de stare ale switch-ului cu idx-ul 267
    execute = function(dz)
        local currentDate = os.date('*t')
        local switchIdxToControl = 23
        local requiredSwitchIdx = 267
        -- Verificăm dacă switch-ul cu idx-ul 267 este ON
        local requiredSwitchState = dz.devices(requiredSwitchIdx).state
        if requiredSwitchState == 'On' then
            -- Dacă suntem în decembrie sau ianuarie, pornim switch-ul cu idx-ul 23
            if currentDate.month == 12 or currentDate.month == 1 then
                dz.devices(switchIdxToControl).switchOn()
                -- În orice altă lună, oprim switch-ul cu idx-ul 23
                dz.devices(switchIdxToControl).switchOff()
            -- Dacă switch-ul cu idx-ul 267 nu este ON, asigurăm că switch-ul cu idx-ul 23 este oprit
