Christmas light by program
ssk17051980
- Domoticz version: 2023.2
I keep trying to make a script even with the help of chat-open-ai, but without success.
my script must turn on a switch, with idx=x, in the period 01.12 - 05.01, for a period of 8 hours, IF another switch with idx=y, is ON.
it is about Christmas lights, and idx=y is a switch that is ON when the sun goes down.
Does anyone have something like this already done and working?
Thank you
Thank you
willemd
- Domoticz version: 2026.3
Re: Christmas light by program
Not sure if this timer works, please go ahead and test it.
Alternatively you just could use the "at sunrise" or "at sunset" trigger, then you don't need to check the y switch.
local idxSunDownSwitch=y
local idxLightsSwitch=x
timer {
'every minute on 01/12-05/01',
logging = {
level = domoticz.LOG_INFO,
marker = 'christmas light',
execute = function(domoticz, timer)
domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO)
if domoticz.devices(idxSunDownSwitch).state=='ON' then
if domoticz.devices(idxLightsSwitch).state=='OFF' then
domoticz.devices(idxLightsSwitch).switchOn()
if domoticz.devices(idxLightsSwitch).state=='ON' then
domoticz.devices(idxLightsSwitch).switchOff()
- gizmocuz
Indded, why not add a timer to your Cristmas light to go on 30 minutes before sunset ?
ssk17051980
gone testwillemd wrote: Tuesday 02 January 2024 19:09 Not sure if this timer works, please go ahead and test it.
local idxSunDownSwitch=y local idxLightsSwitch=x return { on = { timer { 'every minute on 01/12-05/01', } }, logging = { level = domoticz.LOG_INFO, marker = 'christmas light', }, execute = function(domoticz, timer) domoticz.log('Timer event was triggered by ' .. timer.trigger, domoticz.LOG_INFO) if domoticz.devices(idxSunDownSwitch).state=='ON' then if domoticz.devices(idxLightsSwitch).state=='OFF' then domoticz.devices(idxLightsSwitch).switchOn() end else if domoticz.devices(idxLightsSwitch).state=='ON' then domoticz.devices(idxLightsSwitch).switchOff() end end end }
thx
ssk17051980
i want to be ON in a specific intervalgizmocuz wrote: Wednesday 03 January 2024 8:49 Indded, why not add a timer to your Cristmas light to go on 30 minutes before sunset ?
willemd
Exactly, that's what he meant: go ON xx minutes before or after sunset, go OFF xx minutes before or after sunrise.
Reading the dzVents documentation will help
You can do this with the normal timer function/button too, no need to program something.willemd wrote: Wednesday 03 January 2024 13:53 Exactly, that's what he meant: go ON xx minutes before or after sunset, go OFF xx minutes before or after sunrise.
ssk17051980
local idxSunDownSwitch = 267 --indicate the sunrise and sunset /apus (ON/OFF)
local idxLightsSwitch = 23 -- the switch that i want to control (ON/OFF)
timer = {
'every minute on 12/01-01/05',
logging = {
local sunDownSwitch = domoticz.devices(idxSunDownSwitch)
local lightsSwitch = domoticz.devices(idxLightsSwitch)
if sunDownSwitch.state == 'ON' then
if lightsSwitch.state == 'OFF' then
lightsSwitch.switchOn()
if lightsSwitch.state == 'ON' then
lightsSwitch.switchOff()
willemd
If you want help you need to provide some more feedback and info.
I tested the timer trigger and see my script is launched every minute, so that is not the problem.
Is yours launched as well? Is it activated?
Any error messages?
Any info in the log file?
Did you add debug info so that it is shown in the logfile?
Any error messages?
ssk17051980
it's working in this form.
I have to change the interval now.
1 Dec - 10 January
1 Dec - 10 January
timer = { 'daily' },
devices = { 267 } -- Se activează și la schimbările de stare ale switch-ului cu idx-ul 267
execute = function(dz)
local currentDate = os.date('*t')
local switchIdxToControl = 23
local requiredSwitchIdx = 267
-- Verificăm dacă switch-ul cu idx-ul 267 este ON
local requiredSwitchState = dz.devices(requiredSwitchIdx).state
if requiredSwitchState == 'On' then
-- Dacă suntem în decembrie sau ianuarie, pornim switch-ul cu idx-ul 23
if currentDate.month == 12 or currentDate.month == 1 then
dz.devices(switchIdxToControl).switchOn()
-- În orice altă lună, oprim switch-ul cu idx-ul 23
dz.devices(switchIdxToControl).switchOff()
-- Dacă switch-ul cu idx-ul 267 nu este ON, asigurăm că switch-ul cu idx-ul 23 este oprit
