Is there a Dynamic DNS script?
BarryT
- Domoticz version: 2024.3
Hi all, is there a (freedns) script around that will update a dynamic dns url and push data into domoticz?
I have a direct url wich only needs to be opened to update my dynamic dns wan ip, it would be great to do this from inside domoticz.
Thanks a lot!
Merry Christmas
Thanks a lot!
Merry Christmas
- habahabahaba
- Domoticz version: 2024.4
Re: Is there a Dynamic DNS script?
If you need only to open known url you can use dzvents script that will make it by timer as often as you need
by using
domoticz.openURL('<YOUR_URL>')
by using
BarryT
So, only curling an url is not the thing, i want also a virtual device with wan ip and when it has updated.. any examples? Pardon me, maybe i was not clear enough. Thanks!
- habahabahaba
Still not sure what do you want.
Any notifyer with you current ip ?
BarryT
I want domoticz let do my dynamic dns update and update an virtual device as well when the ip has changed and updated
- habahabahaba
So, first you need to know what is your IP now (for example here)
Then you can push it where you want
BarryT
I know, but that is still not a script
I was hoping that someone has some script or similar already
- habahabahaba
timer = {
'every minute' -- just an example to trigger the request
httpResponses = {
'GettingIP' -- название должно совпадать с методом Callback ниже
logging = {
level = domoticz.LOG_INFO,
marker = 'GettingIP',
local ip_url = 'https://api.ipify.org/?format=json'
if (item.isTimer) then
domoticz.openURL({
method = 'GET',
url = ip_url,
callback = 'GettingIP', -- see httpResponses above.
}).afterSec(1)
if (item.isHTTPResponse) then
if (item.ok) then
if (item.isJSON) then
local jsonParser = require('JSON')
local json1 = jsonParser:decode(item.data)
local currentIP = json1['ip'] --
local devIdx = 40 -- idx of your text device with current ip
domoticz.devices(devIdx).updateText('Current ip: '..currentIP)
domoticz.log('Current IP: '.. currentIP, domoticz.LOG_INFO)
--- uncomment and put your data
--[[domoticz.openURL({
method = 'POST',
url = '<YOUR POST URL WITH CUR IP>',
callback = 'Updating IP', -- see httpResponses above.
}).afterSec(1)]]--
--OOOPS
domoticz.log('ERROR', domoticz.LOG_ERROR)
domoticz.log(item, domoticz.LOG_ERROR)
BarryT
Great!! Thank you very much! Going to try tonighthabahabahaba wrote: Tuesday 26 December 2023 19:252023-12-26_21-30-12.pngCode: Select all
-- 123 return { on = { timer = { 'every minute' -- just an example to trigger the request }, httpResponses = { 'GettingIP' -- название должно совпадать с методом Callback ниже } }, logging = { level = domoticz.LOG_INFO, marker = 'GettingIP', }, execute = function(domoticz, item) local ip_url = 'https://api.ipify.org/?format=json' if (item.isTimer) then domoticz.openURL({ method = 'GET', url = ip_url, callback = 'GettingIP', -- see httpResponses above. }).afterSec(1) end if (item.isHTTPResponse) then if (item.ok) then if (item.isJSON) then local jsonParser = require('JSON') local json1 = jsonParser:decode(item.data) local currentIP = json1['ip'] -- local devIdx = 40 -- idx of your text device with current ip domoticz.devices(devIdx).updateText('Current ip: '..currentIP) domoticz.log('Current IP: '.. currentIP, domoticz.LOG_INFO) --- uncomment and put your data --[[domoticz.openURL({ method = 'POST', url = '<YOUR POST URL WITH CUR IP>', callback = 'Updating IP', -- see httpResponses above. }).afterSec(1)]]-- end else --OOOPS domoticz.log('ERROR', domoticz.LOG_ERROR) domoticz.log(item, domoticz.LOG_ERROR) end end end }
