New RFLink firmware (R50) now available!
Check here: http://www.rflink.nl/
Changelog:
RFLink v1.1 R50
- New Device: Abalon Curtain remote (BE301) (receive)
- New Device: Lanboo Curtain remote (receive)
- New Device: Zaffer Blinds remote (receive)
- New Device: Marimex Pool Thermometer
- New Device: Gira 225500
- New Device: Deltia 8.33 - Thermostat - X2D
- New Device: Deltia 8.03 - Thermostat - X2D REF 6050417
- New Device: Deltia 1.03 - 3 zone - X2D (including support for pairing/association)
- New Device: Calybox 220 - 3 zone - X2D
- New Device: DPM Switch sets (Thanks: Olaf)
- New Device: Universal Blyss receptor ref 582857
- Added: Acurite 899 rain meter (Thanks: Peter)
- Added: Funkbus transmit
- Added: Another Chinese screen motor set following a Dooya variant
- Added: Additional Hager support
- Added: Oregon THN129
- Added: Broadlink SmartOne S1C sensors
- Added: Tellstick Temperature and humidity sensors (Thanks: Ivan)
- Added: Viking 02038 Temperature and Humidity sensor
- Added: Viking 02042 Temperature sensor and Rain meter
- Added: option to force WH2 protocol for some sensors in case of incorrect detection
- Fixed: HomeEasy HE100
- Fixed: Froggit F007TH decoding issues
- Fixed: Viking negative temperatures
- Fixed: Alecto V4 better handling when multiple devices are used
- Fixed: Conrad Pool Thermometer recognition
- Fixed: Banggood SKU174397 allowing multiple devices
- Fixed: Various changes to RTS to improve detection
- Changed: massive overhaul of the code to clean up and free important resources
- Changed: RTS: Increased number of supported devices to 32
- Removed: QRFdebug, use RFDebug for all logging
- Stuntteam
- Xenomes
- Domoticz version: 2026.4
Re: New RFLink firmware (R50) now available!
Yes, very nice! Congratulations on the new version! Will it be updated faster in the future now that the code is more optimized?
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Tinytuya
- Stuntteam
Yes, thats the idea
- Xenomes
Very nice! I have two devices that are not recognized. I will try to capture the pulses and send them to the mentioned email on the website. The only problem is that there are a lot of signals in the air. I will try to isolate them!
Tinytuya
Tinytuya
Kedi
- Domoticz version: latest
Nice that there is a new version and hopefully some more in the future.
Just wondering if source code will be released on Github or other platforms?
- Stuntteam
It depends a bit on the type of device but sometimes unfiltered logs are working better than cleaned/isolated data..Xenomes wrote: Tuesday 26 December 2023 19:38 The only problem is that there are a lot of signals in the air. I will try to isolate them!
- Xenomes
They are both temp/hum. meters, I will try to make a capture.Stuntteam wrote: Friday 29 December 2023 16:17 It depends a bit on the type of device but sometimes unfiltered logs are working better than cleaned/isolated data..
Edit: I have email the result of the capture.
Tinytuya
Tinytuya
