New RFLink firmware (R50) now available!
433Mhz opensource Receiver & Transmitter.
Stuntteam
Post by Stuntteam »
Check here: http://www.rflink.nl/
Changelog:
RFLink v1.1 R50
- New Device: Abalon Curtain remote (BE301) (receive)
- New Device: Lanboo Curtain remote (receive)
- New Device: Zaffer Blinds remote (receive)
- New Device: Marimex Pool Thermometer
- New Device: Gira 225500
- New Device: Deltia 8.33 - Thermostat - X2D
- New Device: Deltia 8.03 - Thermostat - X2D REF 6050417
- New Device: Deltia 1.03 - 3 zone - X2D (including support for pairing/association)
- New Device: Calybox 220 - 3 zone - X2D
- New Device: DPM Switch sets (Thanks: Olaf)
- New Device: Universal Blyss receptor ref 582857
- Added: Acurite 899 rain meter (Thanks: Peter)
- Added: Funkbus transmit
- Added: Another Chinese screen motor set following a Dooya variant
- Added: Additional Hager support
- Added: Oregon THN129
- Added: Broadlink SmartOne S1C sensors
- Added: Tellstick Temperature and humidity sensors (Thanks: Ivan)
- Added: Viking 02038 Temperature and Humidity sensor
- Added: Viking 02042 Temperature sensor and Rain meter
- Added: option to force WH2 protocol for some sensors in case of incorrect detection
- Fixed: HomeEasy HE100
- Fixed: Froggit F007TH decoding issues
- Fixed: Viking negative temperatures
- Fixed: Alecto V4 better handling when multiple devices are used
- Fixed: Conrad Pool Thermometer recognition
- Fixed: Banggood SKU174397 allowing multiple devices
- Fixed: Various changes to RTS to improve detection
- Changed: massive overhaul of the code to clean up and free important resources
- Changed: RTS: Increased number of supported devices to 32
- Removed: QRFdebug, use RFDebug for all logging
Xenomes
Domoticz version: 2026.4
Re: New RFLink firmware (R50) now available!
Post by Xenomes »
Yes, very nice! Congratulations on the new version! Will it be updated faster in the future now that the code is more optimized?
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.4 LTS (64Bit) - Domoticz 2026.4 (Docker)
Tinytuya
Stuntteam
Post by Stuntteam »
Yes, thats the idea :)
Xenomes
Post by Xenomes »
Very nice! I have two devices that are not recognized. I will try to capture the pulses and send them to the mentioned email on the website. The only problem is that there are a lot of signals in the air. I will try to isolate them!
Tinytuya
Kedi
Domoticz version: latest
Post by Kedi »
Nice that there is a new version and hopefully some more in the future.
Just wondering if source code will be released on Github or other platforms?
Stuntteam
Post by Stuntteam »
Xenomes wrote: Tuesday 26 December 2023 19:38 The only problem is that there are a lot of signals in the air. I will try to isolate them!
It depends a bit on the type of device but sometimes unfiltered logs are working better than cleaned/isolated data..
Xenomes
Post by Xenomes »
Stuntteam wrote: Friday 29 December 2023 16:17 It depends a bit on the type of device but sometimes unfiltered logs are working better than cleaned/isolated data..
They are both temp/hum. meters, I will try to make a capture.
Edit: I have email the result of the capture.
Tinytuya
