Hello
Is it possible to connect the BH1750 lighting intensity sensor directly via Raspberry GPIO to Domoticz and read the value?
Currently I have it through the weather station but I would like to build a raspberry backup with lux reading in the event of a power failure. Now I would also have to maintain the main router and the Wi-Fi access point from which the station receives the Wi-Fi signal to connect to the network and Domoticz.
I checked in Domoticz from settings -> hardware and the BH1750 sensor is missing in I2C
Domoticz + sensor lux BH1750
Daro1003
- Domoticz version: 2023.1
- Sprzęt.jpg (43.8 KiB) Viewed 727 times
- Domoticz version: 2025.1
Re: Domoticz + sensor lux BH1750
If not yet supported with Domoticz integration you could read the sensor with a bash or python script and have that script push the data to a dummy sensor in Domoticz.
Check out this wiki page for examples https://www.domoticz.com/wiki/Scripts
- habahabahaba
- Domoticz version: 2024.4
As a variant
you can use Tuya Zigbee motion sensor ( like this) that includes lux sensor
Then you need zigbeehabahabahaba wrote: Tuesday 28 November 2023 14:23 As a variant
- habahabahaba
Yes you need itwaltervl wrote: Tuesday 28 November 2023 15:31Then you need zigbeehabahabahaba wrote: Tuesday 28 November 2023 14:23 As a variant
you can use Tuya Zigbee motion sensor ( like this) that includes lux sensorDoes this sensor send regular lux updates or only when motion is detected?
As i remember they work independently.
Motion sensor as switch
And lux sensor as... separate device
