homebridge-edomoticz Plugin
loteran
Re: homebridge-edomoticz Plugin
Post by loteran »
Hello everyone,
I've got a problem with edomoticz when I update to V2 1 45-46 or 47.
Homebridge can't load my accessoires, but if I go back to V2 1 40 everything work
With v2 1 45+
[14/11/2023, 19:03:24] Homebridge v1.5.0 (HAP v0.10.2) (Homebridge DCF1) is running on port 51726.
[14/11/2023, 19:03:25] Télé 4EF7 is running on port 32991.
[14/11/2023, 19:03:25] Please add [Télé 4EF7] manually in Home app. Setup Code: 577-00-900
[14/11/2023, 19:03:25] [Domoticz] Could not fetch data for AppLamp All. (Device might have been removed?)
[14/11/2023, 19:03:25] [Domoticz] Could not fetch data for AppLamp Bridge. (Device might have been removed?)
[14/11/2023, 19:03:25] [Domoticz] Could not fetch data for AppLamp Couloir. (Device might have been removed?)
[14/11/2023, 19:03:25] [Domoticz] Could not fetch data for AppLamp Cuisine. (Device might have been removed?)
[14/11/2023, 19:03:25] [Domoticz] Could not fetch data for AppLamp SDB. (Device might have been removed?)
[14/11/2023, 19:03:25] [Domoticz] Could not fetch data for AppLamp Salon. (Device might have been removed?)
[14/11/2023, 19:03:25] [Domoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
Please verify that you have added the MQTT Hardware Device and that the hardware device is enabled.
[14/11/2023, 19:03:26] [Google Smart Home] Connected (1) - wss://homebridge-gsh.iot.oz.nu
[14/11/2023, 19:03:50] [Google Smart Home] Finished instance discovery
[14/11/2023, 19:04:05] [Google Smart Home] Sending Sync Request
[14/11/2023, 19:04:05] [Google Smart Home] Received SYNC intent
Any ideas why it's happend ??? I change nothing, just update and when i go back to v2 40 everything work again I can see my accessories.
Something strange, in v40 I see my accessories, edmoticz can see them and I can switch on or off, but in my logs i got this :
[Domoticz] Device: éteins tout (1798)
[14/11/2023, 19:04:38] [Domoticz] External Device: LG TV - Status (1193)
[14/11/2023, 19:04:38] LG TV - Status BC65 is running on port 33579.
[14/11/2023, 19:04:38] Please add [LG TV - Status BC65] manually in Home app. Setup Code: 577-00-900
[14/11/2023, 19:04:38] [Domoticz] There was an error while getting the MQTT Hardware Device from Domoticz.
[14/11/2023, 19:04:39] [Google Smart Home] Connected (1) - wss://homebridge-gsh.iot.oz.nu
[14/11/2023, 19:05:02] [Google Smart Home] Finished instance discovery
[14/11/2023, 19:05:17] [Google Smart Home] Sending Sync Request
[14/11/2023, 19:05:17] [Google Smart Home] Received SYNC intent
[14/11/2023, 19:05:23] [Google Smart Home] Received QUERY intent
Egregius
Domoticz version: v2024.7
Post by Egregius »
I have some other strange thing now...
Because I moved my Homepod mini to the bathroom I wanted it to start playing music as soon as I turn on the light from the bathroom.
That's when I noticed that the status of the light isn't updated in homebridge/homekit anymore.
When I send a switch command in domoticz homebridge and homekit don't see this until I refresh the homebridge ui accessoires page.
When I send the command from within the home app all is instantly up-to-date.
Tried returning to previous versions from homebridge and from edomoticz plugin but none works.
I also tried with 2 browser windows open. Refreshing one of them results in both being up-to-date. Strange thing...
Any ideas?
Nautilus
Post by Nautilus »
loteran wrote: Tuesday 14 November 2023 18:57 Hello everyone,
With v2 1 45+
I think the api calls were updated in the latest release to reflect what Domoticz is using. Is your Domoticz up to date?
tjabas
Post by tjabas »
since i updated domoticz i keep getting these error messages, and i have traced it back to the edomoticz plugin in homebridge, is there a way to get rid of the errors?
2024-01-12 22:12:53.026 [WebServer] Deprecated RType (devices) for API request. Handled via fallback (getdevices), please use correct API Command! (192.168.1.57)
Domoticz version: 2026.3
Did you update he plugin already?
akamming
Post by akamming »
With v2 1 45+
I see you are on homebridge 1.5 which itself is already on 1.7
i don't know if it fixes your problem. But never a good idea to be on old versions, cause very likely the developers will not test to old versions.
In my setup all works fine and i'm on the latest versions of all products:
- Homebridge 1.7
- Domoticz 2024.1
- Edomoticz 2.1.47
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I'm trying the homebridge-edomoticz Plugin with homebridge and i noticed that my thermostats were not added.
After a search i've found out that is worling with domtoicz 2023.2, but not with 2024.x
Is somebody experiencing the same problems or does somebody has a solution for this?
- Debian 11
- Homebridge 1.7
- Domoticz 2024.4
- Edomoticz 2.1.47
[11-2-2024 15:28:50] Homebridge v1.7.0 (HAP v0.11.1) (Homebridge E72C) is running on port 51012.
[11-2-2024 15:28:50] [Domoticz] Device: Toon Thermostaat (255)
[11-2-2024 15:28:50] [Domoticz] Device: Wnk - Erker (69)
[11-2-2024 15:28:50] [Domoticz] Device: Wnk - Keukenzijde (59)
[11-2-2024 15:28:50] [Domoticz] Device: Wnk - Openhaard (276)
[11-2-2024 15:28:50] [Domoticz] Device: Wnk - Studeerkamer (355)
[11-2-2024 15:28:50] [Domoticz] Device: Wnk - TV (455)
[11-2-2024 15:28:50] [Domoticz] Device: Wnk - Tuinzijde (64)
akamming
Post by akamming »
madpatrick wrote: Sunday 11 February 2024 14:59 Hi,
- Debian 11
- Homebridge 1.7
- Domoticz 2024.4
- Edomoticz 2.1.47
I also use domoticz and homebridge/edomoticz. Thermostat support is edomoticz is very limited: you can Only set the setpoint, where in HomeKit the device can also set heating mode, check current temp, etc… domoticz splits this functionality in 4 devices and that’s why edomoticz. Cannot convert
So I Made my own homebridge plug-in for domoticz thermostats: https://github.com/akamming/homebridge ... thermostat
I suggest you use this one. This also works around your issue and you have a better HomeKit experience
madpatrick
Thanks.
Nice add on for Homebridge.
I've also found a Toon plugin for Homebrdige. SInce i've a Toon Thermostat this works better.
Never the less since Domtoicz 2024.x the thermostats are not working any more with Edomoticz.
So the problem lays with a change of Domoticz or Edomoticz needs an update, because i believe there was change in Domotivz for thermostats
akamming
Post by akamming »
madpatrick wrote: Monday 12 February 2024 12:35 Never the less since Domtoicz 2024.x the thermostats are not working any more with Edomoticz.
best is to log an issue on the github page of edomoticz then i would say
madpatrick
akamming wrote: Monday 12 February 2024 15:04
Already done ;)
https://github.com/PatchworkBoy/homebri ... issues/279
Marci
Domoticz version: 3.8153
Post by Marci »
akamming wrote: Sunday 11 February 2024 18:11 I also use domoticz and homebridge/edomoticz. Thermostat support is edomoticz is very limited: you can Only set the setpoint, where in HomeKit the device can also set heating mode, check current temp, etc… domoticz splits this functionality in 4 devices and that’s why edomoticz. Cannot convert
Alternative is to use homebridge-web-thermostat and NodeRed to knock up a flow that creates the required web endpoints that talk to the required virtual domoticz devices (3x setpoints: Heating, Cooling & Target) & monitors domoticz/in & out MQTT - S'how I've been running thermostats in homebridge for _years_
Screenshot 2024-03-29 at 15.26.13.jpg (199.3 KiB) Viewed 12701 times
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
Marci
Post by Marci »
madpatrick wrote: Monday 12 February 2024 12:35 Already done ;)
Everything merged and published to NPM as v2.1.49 - with a tweak to maintain compatibility with BOTH 2023.x and 2024.x
madpatrick
Marci wrote: Friday 29 March 2024 16:36
Many thanks.
Are there plans to make Groups available ?
Marci
Post by Marci »
What do you mean by “groups”?
madpatrick
Marci wrote: Saturday 18 May 2024 16:59 What do you mean by “groups”?
In Domoticz you have groups and scenes
In a group you multiple devices (switches) you can switch on/off with one click
Wimpi
Domoticz version: 2025.1
Post by Wimpi »
I have been having problems with edomoticz for a few days, don't ask me why right away.
I haven't changed anything in these settings.
Just did an update of Domoticz - Version: 2025.1 (build 16626) - for the Netatmo login problem ...
And since then I think something is wrong.
When I turn a switch on and off in the home app, this also happens in Domoticz, but when I do it the other way around, turn it on and off in Domoticz, nothing happens in the home app ...
Anyone an idea how and why??
"name": "Domoticz RPi5",
"server": "B—W:B**********[email protected]",
"port": "6687",
"roomid": 14,
"mqtt": true,
"ssl": false,
"dimFix": 0,
"legacyBlinds": 0,
"_bridge": { "username": "0E:5D:D5:82:E6:C5", "port": 59759 },
[9/4/2025, 23:09:28] [Domoticz RPi5] Restarting child bridge...
[9/4/2025, 23:09:28] Got SIGTERM, shutting down child bridge process...
[9/4/2025, 23:09:33] [Domoticz RPi5] Child bridge process ended
[9/4/2025, 23:09:33] [Domoticz RPi5] Process Ended. Code: 143, Signal: null
[9/4/2025, 23:09:40] [Domoticz RPi5] Restarting Process...
[9/4/2025, 23:09:41] [Domoticz RPi5] Launched child bridge with PID 55662
[9/4/2025, 23:09:41] Registering platform 'homebridge-edomoticz.eDomoticz'
[9/4/2025, 23:09:41] [Domoticz RPi5] Loaded homebridge-edomoticz v2.1.49 child bridge successfully
[9/4/2025, 23:09:41] Loaded 53 cached accessories from cachedAccessories.0E5DD582E6C5.
[9/4/2025, 23:09:41] [Domoticz RPi5] synchronizeAccessories in progress...
[9/4/2025, 23:09:41] Homebridge v1.9.0 (HAP v0.12.3) (Domoticz RPi5) is running on port 59759.
NOTICE TO USERS AND PLUGIN DEVELOPERS
> Homebridge 2.0 is on the way and brings some breaking changes to existing plugins.
> Please visit the following link to learn more about the changes and how to prepare:
> https://github.com/homebridge/homebridg ... ridge-v2.0
[9/4/2025, 23:09:41] [Domoticz RPi5] There was an error while getting the MQTT Hardware Device from Domoticz.
[9/4/2025, 23:19:41] [Domoticz RPi5] synchronizeAccessories in progress...
[9/4/2025, 23:29:41] [Domoticz RPi5] synchronizeAccessories in progress...
[9/4/2025, 23:39:41] [Domoticz RPi5] synchronizeAccessories in progress...
[9/4/2025, 23:49:41] [Domoticz RPi5] synchronizeAccessories in progress...
[9/4/2025, 23:59:41] [Domoticz RPi5] synchronizeAccessories in progress...
Marci
Post by Marci »
Like it says…:
No MQTT = no push ability in that direction.
daniellejorge
Post by daniellejorge »
I'm homebridge orphan!!! What should I substitute homebridge with and be as easy as homebridge to install????
HELP PLEASE!!!! This is so sadddddd.... hehehe.
I want mainly to use google home to control my lights and blinds from domoticz.
