Aqara lumi.remote.b186acn02, werkt niet pizigate
Nivekamoud
lumi.remote.b186acn02, this 1 button switch from Aqara does not work it is not recognized in the pizigate, is there anybody to help with it? maybe an update? I did run the latest beta but did not help.
Aqara WXKG06LM
Plugin: 4.12.001
Domoticz 2020.2 build 12393
https://zigbee.blakadder.com/Aqara_WXKG06LM.html
Aqara WXKG06LM
Plugin: 4.12.001
- Document.zip
- log domoticz
- (1.36 KiB) Downloaded 57 times
- export.zip
- export json
- (4.99 KiB) Downloaded 38 times
Last edited by Nivekamoud on Thursday 24 September 2020 16:57, edited 7 times in total.
Nivekamoud
Re: Aqara lumi.remote.b186acn02, werkt niet pizigate
export toegevoegd
Nivekamoud
Thats fast, i did put the export with the post,
Thanks.
The beta is currently not fully-up-to-date, as we are preparing the new stable version.
The device will be supported there.
Please wait for the next stable version coming soon
In case you want to try before , please do contact me on MP or via keybase.io @pipiche
Nivekamoud
ok, ill wait for the next stable release, thank you for the answer. I really like the pizigate works great.
New stable 4.11 has been release. Could you kindly confirm this works ?
Nivekamoud
Working great, domoticz crashed due to update but the switch worked before the crash.
Verstuurd vanaf mijn SM-G960F met Tapatalk
Good news. UID the crash linked to a domoticz update ?
Nivekamoud
Yes Domoticz beta update, i must install a new version.
- Dutchsea
- Domoticz version: v2023.2
I am trying to include my second Zigbee device: Aqara wireless switch D1 single rocker, WXKG06LM, lumi.remote.b186acn02.
So the same as described above so people got it working before. Also on website https://zigbee.blakadder.com/Aqara_WXKG06LM.html it’s listed as a device that works with Zigbee for Domoticz.
However, I can’t get it to be included. First I activate via the “Zigbee for Domoticz plugin” on port 9440 admin=> provisioning => pairing. And next I push the button on the Aqara switch for 10 seconds till the blue lights flash 3 times. But no new device is added.
I tried this quite a few times without succes.
I am quite new to the Zigbee set-up but adding the first device, a Sonos door sensor, worked quite well.
What can I try to find the reason?
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
- Dutchsea
For the record, the problem was that the battery was to low. The device seem to be working fine (pairing mode was visible by blinking leds) but apparently the battery was to low. Also placing the new device just a few centimeters from the antenna of the controller helped.
Make sense. Pairing requires more energy than on a steady state and that have been seen few times.
Thanks anyway to share that
