MQTT autodiscovery in Domoticz not working
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
Hiu80
Domoticz version: 16182
Post by Hiu80 »
Last week the sensors configured in my Domoticz system stopped working. After deleting and re-adding the MQTT autodiscovery plugin, the sensors are registered as switches, wich do not respond to any command en show no logging. I am using an ESP-32 wich is connected to my boiler, and sends MQTT topics to my mosquitto MQTT server. I add the MQTT AD plugin with the settings of the mosquitto broker.
Reinstalled my raspberry PI with the latest distro Bookworm. Whas running Buster. Reinstalled Domoticz and the latest version of Mosquitto. Edited the security settings to be able to connect to my broker.
Bought a new ESP module to exclude a broken one.
Domoticz version: 2026.3
Re: MQTT autodiscovery in Domoticz not working
Do you see MQTT AD messages with MQTT explorer? https://www.domoticz.com/wiki/MQTT#Debugging_MQTT
Is Domoticz seeing the MQTT broker (Mosquitto)?
What does the domoticz log say (menu setup - Log) if you restart the MQTT AD hardware in Domoticz? Select the MQTT AD hardware in menu setup - hardware and click on update to restart.
Hiu80
Post by Hiu80 »
Yes, I believe so. See screenshot of my MQTT explorer.
Log from domoticz is also attached.
domoticz log.txt
(10.34 KiB) Downloaded 111 times
Looks like you are missing sensor data in the ems-esp topics. So Ems is not sending the data as configured in the homeassistant config topics.
Hiu80
Post by Hiu80 »
Ok, thanks for checking. Just to be sure; it looks like the ems-esp is not doing what it is supposed to be doing?
I will dig further and if i find out what the issue is i will post it here.
Yes it looks like the ems-esp is not doing. See page for all the topics it should send https://emsesp.github.io/docs/MQTT/#published-data
Bospieper
Post by Bospieper »
I have the same problem, how and where can I change the contents of the outbound messages?
Grz. Piet
If that is ems-esp related you have to check the documentation of this tool. See the link in my previous reply.
mvveelen
Post by mvveelen »
Can you try this?
edit /etc/mosquitto/mosquitto.conf and add the following lines:
listener 1883
allow_anonymous true
I moved to Bookworm too and had the same issue, this solved it for me.
