Create a Voltage sensor from utility to dummy
Domoticz version: 2026.3
Re: Create a Voltage sensor from utility to dummy
What error exactly do you get and on what line in the code?
Tarzan737
Post by Tarzan737 »
hi! i get this in the log with latest script
2023-10-11 17:44:08.545 Error: dzVents: Error: (3.1.8) volt: An error occurred when calling event handler Test
2023-10-11 17:44:08.545 Error: dzVents: Error: (3.1.8) volt: ...e/pi/domoticz/scripts/dzVents/generated_scripts/Test.lua:25: attempt to compare number with string
Tarzan737
Post by Tarzan737 »
or is it possible to write a code like this? numbers between instead of > ?
when using this code the log is clean and updating time in voltage sensor but only the value from batt (not correcting value to volt)
return
    on =
        devices =
            'Batt'      -- change to name of voltage device
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when script executes without issues
        marker = 'volt',
    execute = function(dz, item)
        local VoltageDevice = dz.devices('Volt') -- change to name of Custom Sensor for voltage.
        local measuredVoltage = item.rawData[1]
        local Voltage = measuredVoltage
        if measuredVoltage == 500-510 then Voltage=27 end
        dz.log('Voltage = ' .. tostring(Voltage), dz.LOG_DEBUG)
       VoltageDevice.updateVoltage(Voltage)
What do you want to achieve with
As I think it checkes for
measuredVoltage == -10
Also you can change it into
If Voltage == 500 then Voltage=27 end
Tarzan737
Post by Tarzan737 »
ok then it is not what i want..
my final goal is this..
my device Batt has a value (in real world it is a 24v battery charging from 23-27 volts)
and this gives a value from lets say 300 to 520 something from (hardware Denkovi to domotics)
i want to create a dummy volt sensor that translates values to volt..
like Batt value 300-315 is 23Volt, Batt 315-320 is 23.5 volt and so on..
Batt is a custom sensor
Volt is a dummy voltage sensor
You better make it a formula like if 540 is 27 Volt and 300 is 23
Voltage = dz.utils.round(((measuredVoltage-299)/60 + 23) , 1)
But perhaps find better formula on real values and bigger range (10V - 30V)
Tarzan737
Post by Tarzan737 »
Yes this works.. Thanks, can i ask what the 60 do in the formula? how could you findout 60?
edit.. ahh i realized now (Early at morning)
Thank you!!
Great!
I would expect the batt sensor value is lineair to real voltage. so 0 = 0V and 540 = 27 Volt. This would simplify the formula a lot:
Voltage = dz.utils.round(measuredVoltage/20 , 1)
Tarzan737
Post by Tarzan737 »
yes.. i would think that to.. the batt is connected to a device that shut off the load at 23V that is why i wanted it as value 0V
but mayby i should use the entire range as you write 0 = 0V anyway
im very happy about the code you helped me with as it is!
But i have another overkill question (not that important)
if it is possible that the values changes in color in voltage device?
like 23 V is red and => 24V is Green?
if not possible thanks anyway again!!
No that is not possible.
