Python Plugin: Reolink
JBN
Post by JBN »
After searching for a video doorbell for quite some time I finally settled for a Reolink Video Doorbell Wifi. There is a good Python module available to interact with the camera, reolink-aio, created by starkillerOG.
I have created a Domoticz plugin, Domoticz Reolink, to show information from the camera. When creating the plugin I used code and inspiration from Zigbee for Domoticz, mainly to learn more about using asyncio in Domoticz.
Install
git clone https://github.com/j-b-n/domoticz_reolink
Update
git pull
sudo python3 -m pip install -r requirements.txt --upgrade
Github
Domoticz Reolink - https://github.com/j-b-n/domoticz_reolink
Xenomes
Domoticz version: 2025.2
Re: Python Plugin: Reolink
Post by Xenomes »
Nice! I had it sorted by using cam2mqtt and mqtt-mapper plugin, I will test you plugin and switch to it!
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
stack
Domoticz version: 4.11794
Post by stack »
Is plugin working okay?
i will try it wth my coming reolink doorbell
JBN
Post by JBN »
I just tried it with the latest beta and latest reolink_aio and it seems to work.
But I am thinking about changing one of the behaviors. Currently I get a motion-signal "on" from the doorbell and immediately after an "off". It might be better to have the “on” for 30 seconds or something and then return to “off”.
marktn
Post by marktn »
What to fill in here?
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
JBN
Post by JBN »
I am sorry, the name is likely confusing. I'll look into that.
The webhook is created in the camera by the plugin. Thus the Webhook host is the (from the camera) reachable ip-address of the Domoticz server.
In my setup I use 10.0.0.* where my door camera is on 10.0.0.9 and my Domoticz server is 10.0.0.2 (the webhook host). Note that you cannot use 127.0.0.1 (since that is not reachable by the camera).
marktn
Post by marktn »
Thanks for your support!
Do i need to change a setting in the doorbell? Because i have an error.
Webhook Host, is my domoticz IP, Webhook port is domoticz port.
 2023-09-28 19:02:36.392 Status: Reolink deurbel: Started.
2023-09-28 19:02:36.392 Status: Reolink deurbel: Entering work loop.
2023-09-28 19:02:36.514 Error: Reolink deurbel: (Reolink) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/domoticz_reolink/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2023-09-28 19:02:36.514 Error: Reolink deurbel: Traceback (most recent call last):
2023-09-28 19:02:36.514 Error: Reolink deurbel: File "/home/pi/domoticz/plugins/domoticz_reolink/plugin.py", line 64, in <module>
2023-09-28 19:02:36.514 Error: Reolink deurbel: from reolink_aio.api import Host
2023-09-28 19:02:36.514 Error: Reolink deurbel: ModuleNotFoundError: No module named 'reolink_aio'
Domoticz version: 2025.1
Seems that the python module reolink_aio is not installed or not installed correctly. Try to install with sudo.if you already had it installed.
marktn
Post by marktn »
waltervl wrote: Thursday 28 September 2023 19:28 Seems that the python module reolink_aio is not installed or not installed correctly. Try to install with sudo.if you already had it installed.
Did a sudo git pull. Error is still there.
pi@domoticzVM:~/domoticz/plugins/domoticz_reolink$ sudo git pull
[sudo] wachtwoord voor pi:
hint: Pulling without specifying how to reconcile divergent branches is
hint: discouraged. You can squelch this message by running one of the following
hint: commands sometime before your next pull:
hint:
hint:   git config pull.rebase false  # merge (the default strategy)
hint:   git config pull.rebase true   # rebase
hint:   git config pull.ff only       # fast-forward only
hint:
hint: You can replace "git config" with "git config --global" to set a default
hint: preference for all repositories. You can also pass --rebase, --no-rebase,
hint: or --ff-only on the command line to override the configured default per
hint: invocation.
remote: Enumerating objects: 5, done.
remote: Counting objects: 100% (5/5), done.
remote: Compressing objects: 100% (1/1), done.
remote: Total 3 (delta 2), reused 3 (delta 2), pack-reused 0
Unpacking objects: 100% (3/3), 313 bytes | 313.00 KiB/s, done.
From https://github.com/j-b-n/domoticz_reolink
   b7a0bd4..2b89c27  main       -> origin/main
Updating b7a0bd4..2b89c27
Fast-forward
 plugin.py | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
When I go to the plugin repository there is a prerequisite mentioned for reolink_aio. That means you have to install it first before you can use the plugin.
So use command
pip3 install reolink-aio
If it still gives the same error use
sudo pip3 install reolink-aio
marktn
Post by marktn »
waltervl wrote: Thursday 28 September 2023 19:58 When I go to the plugin repository there is a prerequisite mentioned for reolink_aio. That means you have to install it first before you can use the plugin.
So use command
Yes, sudo pip3 install reolink-aio did it.
After install sudo service domoticz stop and start.
Only it is not working. Maybe settings are not okay in domoticz or doorbell?
I have 3 new devices, motion person, motion and doorbell.
Update: Domoticz stopped working. Restored backup, and removed the plugin.
 2023-09-28 20:08:55.061 Reolink: Acquiring GIL for 'onHeartbeatCallback'
2023-09-28 20:08:55.061 Reolink: Calling message handler 'onHeartbeat' on 'module' type object.
2023-09-28 20:08:55.061 Reolink: camera_thread dead - restart!
2023-09-28 20:08:55.062 Reolink: Acquiring GIL for 'onHeartbeatCallback'
2023-09-28 20:09:25.044 Reolink: Pushing 'onHeartbeatCallback' on to queue
2023-09-28 20:09:25.094 Reolink: Processing 'onHeartbeatCallback' message
2023-09-28 20:09:25.094 Reolink: Acquiring GIL for 'onHeartbeatCallback'
2023-09-28 20:09:25.094 Reolink: Calling message handler 'onHeartbeat' on 'module' type object.
2023-09-28 20:09:25.094 Reolink: camera_thread dead - restart!
JBN
Post by JBN »
I need to see if I can reproduce your error. I'll get back to you.
marktn
Post by marktn »
JBN wrote: Thursday 28 September 2023 21:39 I need to see if I can reproduce your error. I'll get back to you.
Thanks! The settings under domoticz are okay? Any settings in the doorbell?
dyter
Domoticz version: 8841
Post by dyter »
For work on my setup, I need to mod this 3 lines in plugin.py:
path = os.getcwd()+"/plugins/domoticz_reolink/camera.py"
self.process = subprocess.Popen(["python", path,
to
path = "/opt/domoticz/userdata/plugins/reolink/camera.py"
self.process = subprocess.Popen(["python3", path,
Work fine, but somes errors appair:
2024-01-07 05:10:45.174 Error: Reolink Parking: Failed to parse message from camera as XML! Length: 1381
2024-01-07 05:10:45.174 Error: Reolink Parking: Failed to parse message from camera as XML! Length: 1759
2024-01-07 11:45:10.557 Error: Reolink Jardin: Failed to parse message from camera as XML! Length: 2801
2024-01-07 11:45:10.558 Error: Reolink Jardin: Failed to parse message from camera as XML! Length: 4714
Domoticz v2024.1 on Synology Docker host, RFLink, ESPEasy wemos D1, Ecodevices, relays x8, dahua doorbell, reolink cameras ....
Rik60
Post by Rik60 »
I have installed the Reolink plugin, i am using a frontdoor videocamera connected via POE. The problem is dat the plugin is not making new devices.
First i had to modify plugin.py, line 134. I changed 127.0.0.1 in the ip adress of the domoticz pi. I left the port on 8989.
If i restart Domoticz the plugin starts without errors (i think) but it doesn't make new devices. What can be the problem?
Rik60
Post by Rik60 »
dyter
Post by dyter »
You need accept new devices in setup of domoticz
Rik60
Post by Rik60 »
dyter wrote: Saturday 27 January 2024 18:13 You need accept new devices in setup of domoticz
Thanks.
I tried, accept new devices (was already set green but still pushed the button for 5 minutes) did not help. In this 5 minutes i restarted the plugin also. No succes....
JBN
Post by JBN »
In the latest version of the plugin (do an update) I have changed to python3 and changed from 127.0.0.1 to self.webhook_host.
@Rik60 - You should find the devices under the Devices tab. If Domoticz can not create the devices the error message is "Unit creation failed, Domoticz settings prevent accepting new devices."
The logs you have posted is the complete log from the plugin?
You should see something like this:
2024-01-28 15:37:34.254 Reo: Worker thread started.
2024-01-28 15:37:34.254 Status: Reo: Entering work loop.
2024-01-28 15:37:34.255 Status: Reo: Started.
2024-01-28 15:37:34.662 Status: Reo: Initialized version 0.0.2, author 'jbn'
2024-01-28 15:37:41.592 Reo: Camera Name : Doorbell
2024-01-28 15:37:41.593 Reo: Camera Model : Reolink Video Doorbell WiFi
2024-01-28 15:37:41.593 Reo: Camera Hardware version : DB_566128M5MP_W
2024-01-28 15:37:41.593 Reo: Camera Software version : v3.0.0.2555_23080700
2024-01-28 15:37:41.593 Reo: Camera Mac_address : ##############
2024-01-28 15:37:41.593 Reo: Camera Is doorbell : True
2024-01-28 15:37:41.593 Reo: Camera AI supported : True
2024-01-28 15:37:41.593 Reo: Camera AI types : ['people']
Rik60
Post by Rik60 »
JBN wrote: Sunday 28 January 2024 15:40 In the latest version of the plugin (do an update) I have changed to python3 and changed from 127.0.0.1 to self.webhook_host.
Thanks.
I have update the plugin and changed some setting in the camera. It seems to work now, there is one device created, a motion sensor (switch). How many devices should be created, just one or 1 switch motion (motion), 1 switch motion (person) and 1 switch doorbell?
Thanks for your help
