Zigbeefordomoticz : TS0601-eTRV7 no decimals in temp
hyeronimo
Post by hyeronimo »
I have been using several TS0601-eTRV7 thermostat valves for some time. I have also got some Sonoff temp/hum sensors connected and it occured to me that the TRV's are only giving integer temperature values , while the Sonoff sensors are reporting with one decimal.
The TRV graphs are kind blocky because of this. Can this somehow be changed in the parameters?
Best regards,
Jeroen
Screenshot 2023-09-14 162730.png (21.7 KiB) Viewed 461 times
pipiche
Re: Zigbeefordomoticz : TS0601-eTRV7 no decimals in temp
Post by pipiche »
I’ll have a look, but I suspect that the device is sending data like that
hyeronimo
Post by hyeronimo »
Hi Pipiche,
It seems originally they could use steps of 0,5 degrees C, judging from the TUYA export:
"code": "temp_current",
"name": "当前温度",
"type": "Integer",
"values": "{\"unit\":\"℃\",\"min\":-100,\"max\":500,\"scale\":1,\"step\":5}"
Assuming the -100 means minus 10 degrees C and 500 means 50 degrees C.
hope you can help here! thanks in advance.
