I recently did an update and one device is missing - let's call it 241 (P1 Smart Meter)
It's neither visible in the untility tab nor in the hardware list.
In the DB it's there - in MultiMeter_Carlendar and DeviceStatus
Other P1 Meters are there and working properly.
When i open https://ip/#/Devices/241/Log i get the right name on top but >no data to display< in every graph
Does anyone have an idea, why 241 keeps hiding everywhere in the GUI or what entry sould i check in the DB? I really want to keep it, since i've a year worth of historical data.
-fipse
domoticz 2023,2 on raspi
Device lost in Hardware, Found it in DB
- Domoticz version: 2026.3
Re: Device lost in Hardware, Found it in DB
did you empty the assigned devices list of the admin user in menu Setup-Users?
When the related hardware gateway (menu setup - hardware) was disabled did you unset setting Hide disabled hardware devices in menu Setup - Settings?
fipse
1, yes it's all on the left
2. it's a "dummy" sensor, therfore is must be running. "Hide Disabled Hardware Sensors" is deactivated.
any other idea?
-fipse
any other idea?
-fipse
