I use a shelly 3em, integrated in domoticz with Shelly MQTT.
I don't know how to see the total consumption per month or at least per month. for example from 01.01.2023 to 31.01.2023. is there someone who can make me a script or another solution for the event, even for a fee?
Shelly 3em monitor
ssk17051980
- Domoticz version: 2023.2
Shelly 3em monitor
- shelly 3 EM.jpg (140.44 KiB) Viewed 3881 times
dmitrij
Re: Shelly 3em monitor
In my Shelly Android app i have a tab named "Monthly Reports". This tab is empty with a comment, which says "To receive the monthly reports, you need to be a premium user."
So, If you plan to have monthly stats from Shelly - you need premium subscription. If you want to calculate such stats in Domoticz - you need process data there.
I just started using Shelly 3EM and also look for same solution.
- Domoticz version: 2025.1
Just go to the report page of the device (click on Log and then Report) and you can go back for years. See wiki page https://www.domoticz.com/wiki/Managing_ ... ice_Report
Also the Log page gives already a lot of data
imautohuttraeger
I also have a Shelly 3EM via Shelly MQTT. How do you get the "instant consumption"? I only have things like voltage, ampere and powerfactor, but not the actual power in watt.
Do I have to calculate it via script? I am strugling with this.
- gizmocuz
You could use MQTT Auto Discovery and create config objects for the shelly MQTT outputs
For example:
homeassistant/sensor/shellyem-1-0/power/config
homeassistant/sensor/shellyem-1-0/total/config
Make sure all id's are unique and you group the power/usage like above
Example for the voltage
homeassistant/sensor/shellyem-1-0/voltage/config
I am using a application called MQTT Explorer.
Make sure the config objects you publish with the 'retain' topic set, so the will always be there
Once they are in Domoticz you should get monthly year graphs/reports
Once you have all 3 phases in Domoticz, you could create a script that generates a P1 Meter from these values
For example:
"dev": {
"ids": [
"485519DABF59"
"name": "shellyem-1 Power 0 R",
"stat_t": "~emeter/0/power",
"avty_t": "~online",
"pl_avail": "true",
"pl_not_avail": "false",
"enabled_by_default": true,
"uniq_id": "485519DABF59_0_power",
"qos": 0,
"~": "shellies/shellyem-1/",
"dev_cla": "power",
"stat_cla": "measurement",
"unit_of_meas": "W",
"val_tpl": "{{value|float|round(1)}}"
"dev": {
"ids": [
"485519DABF592"
"name": "shellyem-1 Total 0",
"stat_t": "~emeter/0/total",
"pl_avail": "true",
"uniq_id": "485519DABF592_0_total",
"qos": 0,
"dev_cla": "energy",
"la_te": true,
"stat_cla": "total_increasing",
"unit_of_meas": "Wh",
"val_tpl": "{{value|round(2)}}"
"dev": {
"ids": [
"485519DABF59"
"name": "shellyem-1 Voltage 0",
"stat_t": "~emeter/0/voltage",
"uniq_id": "485519DABF59_0_voltage",
"qos": 0,
"dev_cla": "voltage",
"unit_of_meas": "V",
"val_tpl": "{{value|float|round(1)}}",
"pl_avail": "true",
imautohuttraeger
Thank you! I will have a look on it (will last a while until I will have enough time) and try if I can work it out. But I think it will be too sophisticated for a guy like me, who is just a user with very little programming skills and knowledge.
However, what I managed meanwhile is, to sum up Voltage, Ampere and Powerfactor via dzVents Script (a lot of copy and paste and help by ChatGPT
) and fill a virtual device with it. It works wit a custom device. But when I try to use a virtual device of Type electric usage, it receives no data.
