Support for free Openweather
- Domoticz version: 2025.1
As per recent discussion, it would be great if weather-block would support the free plan as well.
Link to relevant post with code : viewtopic.php?p=304716#p304716
Re: Support for free Openweather
Dashticz supports OWM 3, which is free for 1000 calls per day.
OpenWeatherMap doesn't support the 2.5 API for new accounts.
Can you use owm3?
Can you use owm3?
Yes, of course. But it involves giving payment info and I think it should be avoidable.
Just looking at the code, support for the free version should be easy to implement. That's why I'm asking.
I understand if this is not a priority -- or even worth the trouble.
Can you give a link to the free version? I've only seen the 3.0 version, for which you indeed have to provide payment info.MasMat wrote: ↑Wednesday 09 August 2023 7:41 Yes, of course. But it involves giving payment info and I think it should be avoidable.
So the free version just requires sign-up and no credit card info etc (verify email I think was all I had to do):
https://openweathermap.org/price
The link "Get API key" just makes you create a sign-up and from there you can create API keys.
The limits are 60 calls/min and 1M/month.
Once you have the free API key, this link (viewtopic.php?p=304716#p304716) shows the API-call address difference.
Could this usage be implemented simply by adding a new "provider" for example "owm_free"?
Excellent.
I'll add that.
I'll add that.
Wow! Thanks!
I've added support for the free OWM account to the latest Dashticz beta.MasMat wrote: ↑Tuesday 15 August 2023 7:26 So the free version just requires sign-up and no credit card info etc (verify email I think was all I had to do):
Can you test?
Update Dashticz with :
git checkout beta
git pull
- Domoticz version: 2024.6
I have been using this for about a year; it's great for predictions, I use "Minimum Temperature Tonight" in a lot of scripts. I've never had to pay.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
Yeah! Quick test and it works.
I still have to tune my weather block but it's displaying data nicely.
Big thanks and mucho respect to the community
