Support for free Openweather
MasMat
Domoticz version: 2025.1
Post by MasMat »
As per recent discussion, it would be great if weather-block would support the free plan as well.
Link to relevant post with code : viewtopic.php?p=304716#p304716
Lokonli
Re: Support for free Openweather
Post by Lokonli »
Dashticz supports OWM 3, which is free for 1000 calls per day.
OpenWeatherMap doesn't support the 2.5 API for new accounts.
Can you use owm3?
MasMat
Post by MasMat »
Yes, of course. But it involves giving payment info and I think it should be avoidable.
Just looking at the code, support for the free version should be easy to implement. That's why I'm asking.
I understand if this is not a priority -- or even worth the trouble.
Lokonli
Post by Lokonli »
MasMat wrote: Wednesday 09 August 2023 7:41 Yes, of course. But it involves giving payment info and I think it should be avoidable.
Can you give a link to the free version? I've only seen the 3.0 version, for which you indeed have to provide payment info.
MasMat
Post by MasMat »
So the free version just requires sign-up and no credit card info etc (verify email I think was all I had to do):
https://openweathermap.org/price
The link "Get API key" just makes you create a sign-up and from there you can create API keys.
The limits are 60 calls/min and 1M/month.
Once you have the free API key, this link (viewtopic.php?p=304716#p304716) shows the API-call address difference.
Could this usage be implemented simply by adding a new "provider" for example "owm_free"?
Lokonli
Post by Lokonli »
Excellent.
I'll add that.
MasMat
Post by MasMat »
Wow! Thanks! :D
Lokonli
Post by Lokonli »
MasMat wrote: Tuesday 15 August 2023 7:26 So the free version just requires sign-up and no credit card info etc (verify email I think was all I had to do):
I've added support for the free OWM account to the latest Dashticz beta.
Can you test?
Update Dashticz with :
git checkout beta
git pull
Remove the 'provider' block parameter, of set it to 'owmfree'
solarboy
Domoticz version: 2024.6
Post by solarboy »
I have been using this for about a year; it's great for predictions, I use "Minimum Temperature Tonight" in a lot of scripts. I've never had to pay.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
MasMat
Post by MasMat »
Yeah! Quick test and it works.
I still have to tune my weather block but it's displaying data nicely.
Big thanks and mucho respect to the community :D
