custom sensor with 4 inputs Topic is solved
adeibiza
i have an ec probe which gives me conductivity, ppm, salinity & specific gravity
i can't see a way of sending all 4 to one dummy sensor ?
i could set up 4 custom sensors & then split the data in the one script and send 4 times but that seems inefficiant
- Domoticz version: 2026.3
Re: custom sensor with 4 inputs
No, unfortunately not possible.
peterbos
With a text device instead of a sensor device and a script that puts all 4 values in the text field of that text device?
Peter
Peter
adeibiza
an idea, but i ended up with 4 custom sensors in the end & some copying and pasting
ecvalue1 =values[0]
ecvalue2 =values[1]
ecvalue3 =values[2]
ecvalue4 =values[3]
cmd1 = url_json1 + str(idx1) + "&nvalue=0&svalue="+ecvalue1+";"
print (cmd1)
hf1 = urllib2.urlopen(cmd1)
hf1.close
time.sleep(1)
cmd2 = url_json2 + str(idx2) + "&nvalue=0&svalue="+ecvalue2+";"
print (cmd2)
hf2 = urllib2.urlopen(cmd2)
hf2.close
time.sleep(1)
cmd3 = url_json3 + str(idx3) + "&nvalue=0&svalue="+ecvalue3+";"
print (cmd3)
hf3 = urllib2.urlopen(cmd3)
hf3.close
time.sleep(1)
cmd4 = url_json4 + str(idx4) + "&nvalue=0&svalue="+ecvalue4+";"
print (cmd4)
hf24 = urllib2.urlopen(cmd4)
hf4.close
time.sleep(1) -
peterbos
This is just a snippet. In which of the script languages? In dzVents your problem can be solved, I think. The other languages I don't know or don't use.
Peter
Peter
adeibiza
the full code for you, python2.7 on a raspberry pi using an atlas scientific K.1 ec probe
import io # used to create file streams
import fcntl # used to access I2C parameters like addresses
import time
import string # helps parse strings
import datetime as dt
import urllib2
idx1 = 19
url_json1 = "http://192.168.1.170:8080/json.htm?type=command¶m=udevice&idx="
idx2 = 20
url_json2 = "http://192.168.1.170:8080/json.htm?type=command¶m=udevice&idx="
idx3 = 21
url_json3 = "http://192.168.1.170:8080/json.htm?type=command¶m=udevice&idx="
idx4 = 22
url_json4 = "http://192.168.1.170:8080/json.htm?type=command¶m=udevice&idx="
class atlas_i2c:
long_timeout = 3 # the timeout needed to query readings and calibrations
short_timeout = .5 # timeout for regular commands
default_bus = 1 # the default bus for I2C on the newer Raspberry Pis, certain older boards use bus 0
default_address = 100 # the default address for the pH sensor
def __init__(self, address = default_address, bus = default_bus):
# open two file streams, one for reading and one for writing
# the specific I2C channel is selected with bus
# it is usually 1, except for older revisions where its 0
# wb and rb indicate binary read and write
self.file_read = io.open("/dev/i2c-"+str(bus), "rb", buffering = 0)
self.file_write = io.open("/dev/i2c-"+str(bus), "wb", buffering = 0)
# initializes I2C to either a user specified or default address
self.set_i2c_address(address)
def set_i2c_address(self, addr):
# set the I2C communications to the slave specified by the address
# The commands for I2C dev using the ioctl functions are specified in
# the i2c-dev.h file from i2c-tools
I2C_SLAVE = 0x703
fcntl.ioctl(self.file_read, I2C_SLAVE, addr)
fcntl.ioctl(self.file_write, I2C_SLAVE, addr)
def write(self, string):
# appends the null character and sends the string over I2C
string += "\00"
self.file_write.write(string)
def read(self, num_of_bytes = 31):
current= dt.datetime.now().strftime('%m%d%H%M')
current2 =dt.datetime.now().strftime('%d/%m %H:%M:%S')
# reads a specified number of bytes from I2C, then parses and displays the result
res = self.file_read.read(num_of_bytes) # read from the board
response = [x for x in res if x != '\x00'] # remove the null characters to get the response
if(ord(response[0]) == 1): # if the response isnt an error
char_list = [chr(ord(x) & ~0x80) for x in list(response[1:])] # change MSB to 0 for all received characters except the first and get a list of characters
# NOTE: having to change the MSB to 0 is a glitch in the raspberry pi, and you shouldn't have to do this!
ecvalue = ''.join(char_list)
print(ecvalue)
values = ecvalue.split(",")
print(values[0]) # output: 406700
print(values[1])
print(values[2])
print(values[3])
ecvalue1 =values[0]
ecvalue2 =values[1]
ecvalue3 =values[2]
ecvalue4 =values[3]
print (cmd1)
hf1.close
time.sleep(1)
print (cmd2)
hf2.close
time.sleep(1)
print (cmd3)
hf3.close
time.sleep(1)
print (cmd4)
hf4.close
time.sleep(1)
else:
return "Error " + str(ord(response[0]))
def query(self, string):
# write a command to the board, wait the correct timeout, and read the response
self.write(string)
# the read and calibration commands require a longer timeout
if((string.upper().startswith("R")) or
(string.upper().startswith("CAL"))):
time.sleep(self.long_timeout)
elif((string.upper().startswith("SLEEP"))):
return "sleep mode"
else:
time.sleep(self.short_timeout)
return self.read()
def close(self):
self.file_read.close()
self.file_write.close()
def domo():
print(("loop")+''.join(char_list))
return
def main():
device = atlas_i2c() # creates the I2C port object, specify the address or bus if necessary
i=0
timestamp = 0
output = "0.00"
phvalue = 7
while True:
if (time.time() > timestamp + 10):
try:
output = device.query("R")
#print(output);
except IOError:
print("Query failed")
timestamp = time.time()
i = i+1
if __name__ == '__main__':
main()
- gizmocuz
Just send it to 4 different sensors and be done with it (yes it might take you 5 minutes more coding)
peterbos
I suppose the four values are ecvalue1 to ecvalue4. Why don't you make a string like
(assuming \n is a new line just as in dzVents)
and write that string to a text device:
Peter
str = "Value 1 = " + ecvalue1 + "\nValue 2 = " + ecvalue2 + "\nValue 3 = " + ecvalue3 + "\nValue 4 = " + ecvalue4and write that string to a text device:
cmd1 = "http://192.168.1.170:8080/json.htm?type=command¶m=udevice&idx=" + str(idxTxtdevice) + "&nvalue=0&svalue="+str+";"-
adeibiza
because i'm using a time series graph on grafana
