Enviroment: domoticz on a docker, zwave-js-ui on a docker both on rpi4b with latest rasbian and mosquitto on a docker.
I recently installed zwave-js-ui because my zwave in docker wasnt stable and meshud up my startup.
I installed all my zwave devices in zwvae-js-ui and installed the discovery plugin in domoticz.
It works great and stable!
I have two 2 problems i cant solve on my own, need help ...
1. One zwave device on my 2 floor: a EUROTRONICS SPIRIT VALVE (device Y)with battery becomes dead after including.
i have a Z-Stick S2 USB Controller, and when i take it of my rpi and include the eurotronics on the 2e floor, it does include.
When i attach the z-stick again on my rpi, zwave-js-ui shows the new zwave device (euro..) and tries to get node-info...
But, my controller cant reach this device, but does see another device on the 2e floor, say device X!
2. Can i do something to tell zwave-js-ui to use the zwave device X to communicate with Y and vise versa ?
In zwave domoticz this was easy by clicking the poll entry on a device...
No clue how to do this in zwave-js-ui
I tried
a. i see endpoints and no clue what to do with that and
b. see device configurations values. I added
device X, value: current_value, poll enabled and 10 seconds.no device class or other options set
device X, value: power, poll enabled and 10 seconds. no device class or other options set
but no... discovery of device Y
What do i wrong, do i need endpoint stuff? or other device config values ?
zwave-js-ui and meshing Topic is solved
pvklink
- Domoticz version: latest b
Jablotron connection, Ikea
- JackD
Re: zwave-js-ui and meshing
I still use OpenZwave, so don't exactly know how it work with zwave-js-ui... but I think you have to look for something like "heal network" or "heal node". That function check's routing of the Zwave network. I have also the EUROTRONICS SPIRIT VALVE so I will be following this thread, see if you can get it to work with zwave-js-ui.
- Domoticz version: 2025.1
Perhaps use Zwave-JS-UI nodes health check: https://zwave-js.github.io/zwave-js-ui/ ... ealthcheck
Edit: There seems to be a Heal Network and re-interview Nodes function somewhere in ZwaveJS-UI (Advanced??)
User manual of ZwaveJSUI could use some improvement....
pvklink
Sorry, I did not ask you to do a dump. I just showed you where you possibly do your polling or reconfigure your zwave network routing using a screenshot that was used to do a dump. But you also see a HEAL NETWORK button.
Better ask ZwaveJS to make proper user documentation. On ther other hand, just exploring the Zwave-JS User interface by clicking on all pull down menu's and options will also help you find the correct function.
solarboy
- Domoticz version: 2024.6
There is also the "Ping" node option.
pvklink
Its solved..
The radiator valve seems to be disfunctional. Did some reading on the internet, and it looks like the first editions ór my EUROTRONIC spirit is crap...
