Another Zigbee TRV (TS0601)
Thorgal789
Re: Another Zigbee TRV (TS0601)
Post by Thorgal789 »
Manufacture name _TZE200_a4bpgplm
@pipiche from Z2M this device is locked, need to use the tuya unlock sequence
pipiche
Post by pipiche »
hyeronimo wrote: Monday 27 March 2023 9:16 Hi Pipiche,
Yes I can send you one. It will take a while because I will have to order a new one, all the other ones are installed.
Can you send me your address by pm?
Thanks ,
Jeroen
Jeroen,
I got some $$ funding, if you give the link to purchase the TRV, I'll do, and that will speedup.
hyeronimo
Post by hyeronimo »
Hi Pipiche,
Sorry I have been abroad for a while. This is the link:
https://www.aliexpress.com/item/1005003 ... 1802BvmlNk
pipiche
Post by pipiche »
Unfortunately it is not the one I purchased !
hyeronimo
Post by hyeronimo »
What if I send you some funding through paypal to buy this one too?
pipiche
Post by pipiche »
Yep, funding would be more than welcome.
You can also try to update to the latest version, I have fixed few items
git checkout develop
git pull
sudo python3 -m pip install -r requirements.txt --upgrade
hyeronimo
Post by hyeronimo »
Some great work! Thank you !
I did a pull and reinstalled the module. The module is working.
After pairimg the TRV, device shows up in domoticz,
Thermostat is working and setpoint from domoticz is transferred to TRV
setpoint from TRV is transferred to domoticz.
Thermomode has off, auto and manual and seems to work
Heatingstatus on and off is working
Temperature is working
Valve% is working and the value is synced with the TRV. Only the value shows a factor 10 to high, like 630% instead of 63%
'Door' this must be the open window warning. This would react to a sudden drop in temperature. but the function must be enabled in the app, which only works through the cloud.
I tested with a pack of ice, but the door remained closed.
The manual states that the function should first be enabled in the app, then
"the device will automatically identify whether the window is open. When it is detected that there is cold wind, and the temperature drops by more than 1.5 degr C within 4.5 min, the open-window function will be activated.. At this time the screen displays (a window picture) and the temperature is set t0 12 degr C"
Anyway, this is not an important function to me.
Best regards,
Jeroen
Will transfer some funding
pipiche
Post by pipiche »
I'm very glad that it has move forward. I'll investigate the % and the Door and will purchase one item to provide the best support.
Thanks a lot for the paypal funding - really really help full
pipiche
Post by pipiche »
just did push an update which should cover the % Valve
hyeronimo
Post by hyeronimo »
yes, valve % is working now. Thx!
pipiche
Post by pipiche »
Great
hyeronimo
Post by hyeronimo »
Hi Pipiche,
In the dev branch support for the Sonoff SNZB-02 Temp/Hum sensor (WTGR800 in domoticz) seems broken?
I tried stable, but then the UI did not work in my beta domoticz.
Best regards,
Jeroen
