Zigbee in Domoticz (win10) Topic is solved
olleman
Re: Zigbee in Domoticz (win10)
Post by olleman »
EDIT: googling TS011F gives long threads with other users having this problem so this is most likely due to the switch itself. I got random turn off even when Domoticz was off and zigbee controller disconnected.
Hello again :)
More questions :)
Just the other day I added 2 MOES Switch 2-gang modules. Both of them behave weird. They switch on and off seemingly random. The log in Domoticz doesn't give me any clue since it just says on and off - not who or what initiated it. These are new switches in Domoticz and they are not included in any scripts or Blockly events. I'm wondering if it might be something in the plugin causing this - or perhaps both modules are faulty?
Just a thought. When I compare the MOES switches with the Girier switch they have different Parameters. Could this be in indication that something could be off in the plugin?
girier and moes switch.PNG (17.05 KiB) Viewed 373 times
olleman
Post by olleman »
Sorry for all these questions but I'm eager to learn :)
The GIRIER switch you helped configure the plugin for is also behaving strangely. It seems that most of the time I can't send on/off signal to it and the plugin reports "unreachable" for the GIRIER switch. But the switch seems to be able to send it's status just fine. If I switch the light on the physical switch Domoticz updates it's status instantly.
This switch is on our Garage and according to the Topology scan this is is the only router not having a direct contact with the coordinator. It does, however have contact with 3 other routers and the LQI level is indicated at about 100.
Any thoughts on what's causing this? Almost seems like the mesh network only works "one way" (from router > coordinator)
pipiche
Post by pipiche »
my 2 cents, it would be much better to create a post per subject/issue rather to put everything here
then , when you have an issue, please provides logs on which we could invetsigate, otherwise there is not much we can say
olleman
Post by olleman »
Absolutely, I will do that.
