@pipiche
I am not able to add devices to a group. I can make a new group but not able to add devices to the group. The device disappears after I press on validate.
I did a group scan on devices etc. The groupslist-xx.json file is writable, I see that the group (test) is added to the json.
It worked before but it seems that it is failing after updating to Plugin: 6.3.011
The extra group I had disappeared after the update.
After click on Validate the device dissapears
Zigbee4Domoticz groups
- Domoticz version: 2024.7
Re: Zigbee4Domoticz groups
Addition: After some further testing it seems that I cannot add the devices that were earlier in that disappeared old group.
I can add other devices that were not part of the old group.
Can I reset group settings on a device?
The group is a kind of virtual concept, and in reality each device knows which group it belongs too.
So if you want to reset the group membership of a device you should reset it , if the manufacturer has not make it persistent.
If you want to add a device to a group, and it doesn't happen, in general the device reject to be added. Do you have any logs in the PluginZigbee-xx.log file ?
Wiki is available here.
Zigbee for Domoticz FAQ
See attached log file (with group debug already enabled)
@waltervl is the device you wanted to add is that one ['9d5d' / 'd0cf5efffe291ddf']
Could you kindly give me the export.json of the Plugin Raw Devices ?
Tomorrow evening, not close to my system now.
The devices I want to add in the group are
76c7 90fd9ffffee58799
9d5d d0cf5efffe291ddf
68ac 000d6ffffe268b00
See also attached export
@waltervl I don't see much explaining why it is not successful integrating the group.
Did you try to just Powered Off and the On those Bulb and then create the group ?
Yes, perhaps I have to reset the zigbee devices and re-pair them again.
