Another Zigbee TRV (TS0601)
hyeronimo
Re: Another Zigbee TRV (TS0601)
Hi, devices are not made in domoticz this time. I have to go out for a few hours. Will send more details later.
hyeronimo
I checked the domoticz log for SystemMode
but because no devices were made this time probably no useful info there:
Error: zigbee4domoticz: ValueError: invalid literal for int() with base 16: 'TRV7SystemMode'
deviceinfo seems interesting, see attached files
- _PluginZigbee_51(7).zip
- (66.15 KiB) Downloaded 26 times
- domoticz_log3.txt
- (3.91 KiB) Downloaded 32 times
- deviceinfo3.txt
- (5.19 KiB) Downloaded 34 times
I think your issue was the device was not fully removed.
You need to remove all domoticz widget, then check on the plugin device management that the device is removed and if not you should have a Trash icon to remove it
hyeronimo
I removed the TRV device but not the plugin devices: screenshot is what I have now.l
hyeronimo
oh. removed everything, disabled the plugin, did another git-pull, now I am in trouble, the plugin UI is not working any more. Should have waited with the git pull probably
what do you have in the losg when starting the plugin ?
hyeronimo
domoticz log:
2023-03-19 16:59:29.094 TinyTuya Develop2: onHeartbeat called
2023-03-19 16:59:29.095 TinyTuya Develop2: onHeartbeat called skipped
2023-03-19 16:59:29.567 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 16:59:29.713 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 16:59:31.543 Status: zigbee4domoticz: ZNP Radio register default Ep
2023-03-19 16:59:32.140 Status: zigbee4domoticz: Certified Devices loaded - 457 confs loaded
2023-03-19 16:59:32.145 Status: zigbee4domoticz: Domoticz Widgets usage is at 1.2 % (252 units free)
2023-03-19 16:59:38.076 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 16:59:38.212 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 16:59:39.080 TinyTuya Develop2: onHeartbeat called
2023-03-19 16:59:39.080 TinyTuya Develop2: onHeartbeat called skipped
2023-03-19 16:59:39.678 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 16:59:39.814 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 16:59:39.913 Status: zigbee4domoticz: ZNP Radio manufacturer: Texas Instruments
2023-03-19 16:59:39.913 Status: zigbee4domoticz: ZNP Radio board model: CC1352/CC2652, Z-Stack 3.30+ (build 20210708)
2023-03-19 16:59:39.914 Status: zigbee4domoticz: ZNP Radio version: 3.3
2023-03-19 16:59:39.915 Status: zigbee4domoticz: Network settings
2023-03-19 16:59:39.915 Status: zigbee4domoticz: Channel: 15
2023-03-19 16:59:39.916 Status: zigbee4domoticz: PAN ID: 0x8E53
2023-03-19 16:59:39.916 Status: zigbee4domoticz: Extended PAN ID: 71:ba:b2:e8:82:28:82:f8
2023-03-19 16:59:39.917 Status: zigbee4domoticz: Device IEEE: 00:12:4b:00:2a:2e:c3:f4
2023-03-19 16:59:39.918 Status: zigbee4domoticz: Device NWK: 0x0000
2023-03-19 16:59:39.926 Status: zigbee4domoticz: Number of devices recently active in Coordinator = 2
2023-03-19 16:59:39.927 Status: zigbee4domoticz: [00] DevID: 00 Network addr: da87 IEEE: 00124b0022426f91 LQI: 000 power: ff Model: TH01 ( )
2023-03-19 16:59:39.929 Status: zigbee4domoticz: [01] DevID: 00 Network addr: bed4 IEEE: 04cd15fffe102080 LQI: 000 power: ff Model: TS0601-eTRV7 ( )
2023-03-19 16:59:39.931 Status: zigbee4domoticz: CC1352/CC2652, Z-Stack 3.30+ (znp)
2023-03-19 16:59:39.931 Status: zigbee4domoticz: Installer Version Number: Z-Stack 3.30+ (build 20210708)
2023-03-19 16:59:39.932 Status: zigbee4domoticz: Branch Version: ==> CC1352/CC2652, Z-Stack 3.30+ (znp) <==
2023-03-19 16:59:39.946 Status: zigbee4domoticz: Zigbee Coordinator ieee: 00124b002a2ec3f4 , short addr: 0000
2023-03-19 16:59:39.947 Status: zigbee4domoticz: Network state UP, PANID: 8e53 extPANID: 0x71bab2e8822882f8 Channel: 15
2023-03-19 16:59:46.086 Status: zigbee4domoticz: Request Disabling Accepting new Hardware
2023-03-19 16:59:46.168 Status: zigbee4domoticz: Accepting new Hardware: Disable (Off)
2023-03-19 16:59:48.212 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 16:59:48.354 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 16:59:49.099 TinyTuya Develop2: onHeartbeat called
2023-03-19 16:59:49.099 TinyTuya Develop2: onHeartbeat called skipped
2023-03-19 16:59:51.098 Status: zigbee4domoticz: coordinator set to Certification : 1/CE -> CE
2023-03-19 16:59:51.791 Status: zigbee4domoticz: ota_scan_folder Following Firmware have been loaded
2023-03-19 16:59:51.791 Status: zigbee4domoticz: Plugin with Zigpy, Coordinator CC1352/CC2652, Z-Stack 3.30+ (znp) firmware Znp - Z-Stack 3.30+ (build 20210708) correctly initialized
2023-03-19 16:59:55.958 Buienradar: General/Custom Sensor (Next Rainshower Leadtime)
2023-03-19 16:59:55.966 Buienradar: General/Custom Sensor (Next Rainshower Duration)
2023-03-19 16:59:55.974 Buienradar: General/Custom Sensor (Next Rainshower Avg Rainrate)
2023-03-19 16:59:55.983 Buienradar: General/Custom Sensor (Next Rainshower Max Rainrate)
2023-03-19 16:59:55.995 Buienradar: General/Percentage (Regen-Rain Intensity)
2023-03-19 16:59:56.007 Buienradar: General/Custom Sensor (Regen-Rainfall next Hour)
2023-03-19 16:59:56.153 Error: zigbee4domoticz: Call to function 'onHeartbeat' failed, exception details:
2023-03-19 16:59:56.160 Error: zigbee4domoticz: Traceback (most recent call last):
2023-03-19 16:59:56.160 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1571, in onHeartbeat
2023-03-19 16:59:56.160 Error: zigbee4domoticz: _plugin.onHeartbeat()
2023-03-19 16:59:56.160 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 965, in onHeartbeat
2023-03-19 16:59:56.160 Error: zigbee4domoticz: processListOfDevices(self, Devices)
2023-03-19 16:59:56.160 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 822, in processListOfDevices
2023-03-19 16:59:56.160 Error: zigbee4domoticz: processKnownDevices(self, Devices, NWKID)
2023-03-19 16:59:56.160 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 565, in processKnownDevices
2023-03-19 16:59:56.160 Error: zigbee4domoticz: sanity_check_of_param(self, NWKID)
2023-03-19 16:59:56.160 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/paramDevice.py", line 332, in sanity_check_of_param
2023-03-19 16:59:56.160 Error: zigbee4domoticz: ts0601_actuator( self, NwkId, param, value)
2023-03-19 16:59:56.160 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tuyaTS0601.py", line 69, in ts0601_actuator
2023-03-19 16:59:56.160 Error: zigbee4domoticz: dp = int(ts0601_actuator_dp( self, command, dps_mapping), 16)
2023-03-19 16:59:56.160 Error: zigbee4domoticz: ValueError: invalid literal for int() with base 16: 'TRV7SystemMode'
2023-03-19 16:59:57.010 RaspberryMB: General/Custom Sensor (V3D Clock Speed)
2023-03-19 16:59:57.019 RaspberryMB: General/Custom Sensor (Core Clock Speed)
2023-03-19 16:59:58.353 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 16:59:58.491 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 16:59:59.070 TinyTuya Develop2: onHeartbeat called
2023-03-19 16:59:59.070 TinyTuya Develop2: onHeartbeat called skipped
2023-03-19 16:59:59.931 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 17:00:00.073 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 17:00:00.318 Status: Starting automatic database backup procedure...
2023-03-19 17:00:01.716 Status: Ending automatic database backup procedure...
2023-03-19 17:00:01.074 Error: zigbee4domoticz: Call to function 'onHeartbeat' failed, exception details:
2023-03-19 17:00:01.076 Error: zigbee4domoticz: Traceback (most recent call last):
2023-03-19 17:00:01.076 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1571, in onHeartbeat
2023-03-19 17:00:01.076 Error: zigbee4domoticz: _plugin.onHeartbeat()
2023-03-19 17:00:01.076 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 965, in onHeartbeat
2023-03-19 17:00:01.076 Error: zigbee4domoticz: processListOfDevices(self, Devices)
2023-03-19 17:00:01.076 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 822, in processListOfDevices
2023-03-19 17:00:01.076 Error: zigbee4domoticz: processKnownDevices(self, Devices, NWKID)
2023-03-19 17:00:01.076 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 565, in processKnownDevices
2023-03-19 17:00:01.076 Error: zigbee4domoticz: sanity_check_of_param(self, NWKID)
2023-03-19 17:00:01.076 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/paramDevice.py", line 332, in sanity_check_of_param
2023-03-19 17:00:01.076 Error: zigbee4domoticz: ts0601_actuator( self, NwkId, param, value)
2023-03-19 17:00:01.076 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tuyaTS0601.py", line 69, in ts0601_actuator
2023-03-19 17:00:01.076 Error: zigbee4domoticz: dp = int(ts0601_actuator_dp( self, command, dps_mapping), 16)
2023-03-19 17:00:01.076 Error: zigbee4domoticz: ValueError: invalid literal for int() with base 16: 'TRV7SystemMode'
2023-03-19 17:00:06.091 Error: zigbee4domoticz: Call to function 'onHeartbeat' failed, exception details:
2023-03-19 17:00:06.093 Error: zigbee4domoticz: Traceback (most recent call last):
2023-03-19 17:00:06.093 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1571, in onHeartbeat
2023-03-19 17:00:06.093 Error: zigbee4domoticz: _plugin.onHeartbeat()
2023-03-19 17:00:06.093 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 965, in onHeartbeat
2023-03-19 17:00:06.093 Error: zigbee4domoticz: processListOfDevices(self, Devices)
2023-03-19 17:00:06.094 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 822, in processListOfDevices
2023-03-19 17:00:06.094 Error: zigbee4domoticz: processKnownDevices(self, Devices, NWKID)
2023-03-19 17:00:06.094 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 565, in processKnownDevices
2023-03-19 17:00:06.094 Error: zigbee4domoticz: sanity_check_of_param(self, NWKID)
2023-03-19 17:00:06.094 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/paramDevice.py", line 332, in sanity_check_of_param
2023-03-19 17:00:06.094 Error: zigbee4domoticz: ts0601_actuator( self, NwkId, param, value)
2023-03-19 17:00:06.094 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tuyaTS0601.py", line 69, in ts0601_actuator
2023-03-19 17:00:06.094 Error: zigbee4domoticz: dp = int(ts0601_actuator_dp( self, command, dps_mapping), 16)
2023-03-19 17:00:06.094 Error: zigbee4domoticz: ValueError: invalid literal for int() with base 16: 'TRV7SystemMode'
2023-03-19 17:00:08.486 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 17:00:08.625 EventSystem: Event triggered: WW Wpomp aan_2
2023-03-19 17:00:09.098 TinyTuya Develop2: onHeartbeat called
2023-03-19 17:00:09.098 TinyTuya Develop2: onHeartbeat called skipped
2023-03-19 17:00:10.036 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 17:00:10.172 EventSystem: Event triggered: verwarmingsdraad_aan_2
2023-03-19 17:00:11.105 Error: zigbee4domoticz: Call to function 'onHeartbeat' failed, exception details:
2023-03-19 17:00:11.106 Error: zigbee4domoticz: Traceback (most recent call last):
2023-03-19 17:00:11.106 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1571, in onHeartbeat
2023-03-19 17:00:11.106 Error: zigbee4domoticz: _plugin.onHeartbeat()
2023-03-19 17:00:11.106 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 965, in onHeartbeat
My bad, please get the latest and restart that should be better
hyeronimo
hmm.. not out of the woods yet
2023-03-19 17:39:12.071 Error: zigbee4domoticz: Call to function 'onHeartbeat' failed, exception details:
2023-03-19 17:39:12.074 Error: zigbee4domoticz: Traceback (most recent call last):
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 1571, in onHeartbeat
2023-03-19 17:39:12.074 Error: zigbee4domoticz: _plugin.onHeartbeat()
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 965, in onHeartbeat
2023-03-19 17:39:12.074 Error: zigbee4domoticz: processListOfDevices(self, Devices)
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 822, in processListOfDevices
2023-03-19 17:39:12.074 Error: zigbee4domoticz: processKnownDevices(self, Devices, NWKID)
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/heartbeat.py", line 565, in processKnownDevices
2023-03-19 17:39:12.074 Error: zigbee4domoticz: sanity_check_of_param(self, NWKID)
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/paramDevice.py", line 332, in sanity_check_of_param
2023-03-19 17:39:12.074 Error: zigbee4domoticz: ts0601_actuator( self, NwkId, param, value)
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tuyaTS0601.py", line 84, in ts0601_actuator
2023-03-19 17:39:12.074 Error: zigbee4domoticz: func(self, NwkId, "01", dp )
2023-03-19 17:39:12.074 Error: zigbee4domoticz: File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/tuyaTS0601.py", line 378, in ts0601_child_lock_mode
2023-03-19 17:39:12.074 Error: zigbee4domoticz: data = "%02x" % value
could you please drop the PluginZigbee-xx.log file ?
hyeronimo
I will try to locate it through cli
it is in the Logs/ folder
hyeronimo
Can I save it somehow? It has too many lines to select in nano
hyeronimo
I will copy some stuff:
hundreds of lines with
2023-03-18 16:07:46,091 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 16:07:51,108 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 16:07:56,077 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
hyeronimo
2023-03-18 16:53:21,096 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 16:53:21,772 DEBUG : [ZigpyForwarder_51 1420] tuyaReadRawAPS - bed4/01 fcf: 19 sqn: 74 cmd: 24 Payload: 197424027e
2023-03-18 16:53:21,772 DEBUG : [ZigpyForwarder_51 1420] send_timesynchronisation - bed4/01 UTC: 1679154801 Local: 1679158401
2023-03-18 16:53:21,773 DEBUG : [ZigpyForwarder_51 1420] send_timesynchronisation - bed4/01
2023-03-18 16:53:26,064 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
hyeronimo
2023-03-18 17:09:31,105 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 17:09:32,073 DEBUG : [ZigpyForwarder_51 1420] tuyaReadRawAPS - bed4/01 fcf: 09 sqn: 75 cmd: 01 Payload: 097501007903020004000000b0
2023-03-18 17:09:32,073 DEBUG : [ZigpyForwarder_51 1420] status: 00
2023-03-18 17:09:32,074 DEBUG : [ZigpyForwarder_51 1420] TransId: 79
2023-03-18 17:09:32,075 DEBUG : [ZigpyForwarder_51 1420] working on remaining payload 03020004000000b0 idx: 10
2023-03-18 17:09:32,075 DEBUG : [ZigpyForwarder_51 1420] dp: 3
2023-03-18 17:09:32,076 DEBUG : [ZigpyForwarder_51 1420] datatype: 2
2023-03-18 17:09:32,076 DEBUG : [ZigpyForwarder_51 1420] len_data: 8
2023-03-18 17:09:32,076 DEBUG : [ZigpyForwarder_51 1420] data: 000000b0
2023-03-18 17:09:32,077 DEBUG : [ZigpyForwarder_51 1420] tuyaReadRawAPS - command 01 dp: 3 dt: 2 len: 8 data: 000000b0 idx: 26
2023-03-18 17:09:32,077 DEBUG : [ZigpyForwarder_51 1420] tuya_response - Model: TS0601-eTRV7 Nwkid: bed4/01 dp: 03 dt: 02 data: 000000b0
2023-03-18 17:09:32,077 DEBUG : [ZigpyForwarder_51 1420] ts0601_response - bed4 TS0601-eTRV7 3 2 000000b0
2023-03-18 17:09:32,078 DEBUG : [ZigpyForwarder_51 1420] ts0601_temperature - Temperature bed4 01 17.0
2023-03-18 17:09:36,072 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 17:09:41,088 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
hyeronimo
23-03-18 19:17:56,746 INFO : [ MainThread 1402] Request Disabling Accepting new Hardware
2023-03-18 19:17:56,786 INFO : [ ZigpyCom_51 1419] PERMIT-TO-JOIN: {'cmd': 'PERMIT-TO-JOIN', 'datas': {'Duration': 0, 'targetRouter': 'FFFC'}, 'NwkId': None, 'TimeStamp': 1679163>
2023-03-18 19:17:56,787 INFO : [ ZigpyCom_51 1419] PERMIT-TO-JOIN: duration: 0 for Radio: znp for node: None
2023-03-18 19:17:56,787 INFO : [ ZigpyCom_51 1419] Calling self.app.permit(time_s=0, node=None )
2023-03-18 19:17:56,835 INFO : [ ZigpyCom_51 1419] returning from the self.app.permit(time_s=0, node=None )
2023-03-18 19:18:01,109 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 19:18:06,082 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
2023-03-18 19:18:11,099 INFO : [ MainThread 1402] ts0601_actuator - requesting TRV7WindowDetection 1
hyeronimo
Found a way with cat
- PluginZigbee_51.log.2023-03-18.txt
- (212.36 KiB) Downloaded 43 times
- Pluginzigbee_log_error_history.txt
- (13.94 KiB) Downloaded 34 times
honestly, I'm somehow lost with the logs.
Do you have the possibility to send me the TRV ? So I can work it and return it back after
hyeronimo
Hi Pipiche,
Yes I can send you one. It will take a while because I will have to order a new one, all the other ones are installed.
Can you send me your address by pm?
Thanks ,
Jeroen
Thanks ,
Jeroen
