2023.1 User tab and timer problems
BuderKjell
Domoticz version: 2023.1
Post by BuderKjell »
Running 2023.1 on RPI.
Using Dz for years, updated to 2023.1 three days ago.
Found User tab, but it disappered? Mistake from me?
I am using timer function for some devices like controlling a fan and a couple of lights, that stopped working after the update.
I am currently at the summer house ( in the middle of a forest) and will go back home in a few days, need the timer function. Fan helps circulate hous warming.
Any ideas?
Domoticz version: 2024.7
Re: 2023.1 User tab and timer problems
First clear your browser cache.
User menu is found under Setup
Check the security settings in menu Setup - Settings, Tab Security. Switch on Authorisation for HTTP and check the trusted network IP's
BuderKjell
Cache cleared.
My mistake, found User tab. Running trusted local networks
Under User I have admin defined.
Under User I have Set Devices, did not find explanation in wiki. Should devices be on left or right side?
Need guidance, thank you.
For admin devices list can stay empty
