small & clean text field in Dashticz?
renerene
Post by renerene »
To minimise place on my tablet I would lilke to show some data (temperatures, daily energy price) in a text field. That takes less room than the devices. How can this best be done?
I could make a dummy text sensor, but how to handle end of line returns?
willemd
Domoticz version: 2024.1
Re: text field?
Post by willemd »
I use the log of a text field to show a table.
have a look at the example here
https://user-images.githubusercontent.c ... a9ab04.png
I had to change the default font of domoticz, to make it non-proportional and I had to replace spaces with underscore to get a nice table.
The top line of the log is then shown in the icon, example shown on the same page
https://github.com/WillemD61/battery-planning/
madpatrick
Domoticz version: 2025.1
Re: text field?
Post by madpatrick »
You can make a dummy text sensor in Domoticz and the text can easily confiured in Dashticz
I've several text " blocks" in Dashticz and the text is controlled via a Dzvents script to update the text or control the text
Here an example of Dashticz Screenssaver
2023-02-12 12_33_25-Fully Remote Admin.png (29.76 KiB) Viewed 589 times
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
renerene
Re: text field?
Post by renerene »
madpatrick wrote: Sunday 12 February 2023 12:35 You can make a dummy text sensor in Domoticz and the text can easily confiured in Dashticz
I like the clean layout of these texts.
How do you make multiple lines? A table layout option also would be nice.
Just need something smal to place a lot of textdata in.
madpatrick
Re: small & clean text field in Dashticz?
It is very dependable where the information is coming from.
You can use tables or formatting it by html code
Dashticz is very flexibel
renerene
Post by renerene »
madpatrick wrote: Monday 13 February 2023 20:12 It is very dependable where the information is coming from.
From Domiticz offcourse ;-)
Maybe use dzVents to create some in-between variable / data file?
Sounds promising. Please elaborate. Do you have an example or instructions?
madpatrick
Sure.
This is a part of my DzVents script
        if warmwater.state == "WW" and sensor.state =="On" then
            if not(afzuiging.active) then
                afzuiging.cancelQueuedCommands()
                afzuiging.switchOn().checkFirst()
                local message =  os.date("%H:%M",os.time() ) .. ' Ventilatie staat AAN'
                dz.log(message, dz.LOG_FORCE)
                textblock.updateText(message)
                dz.log('Ventilatie staat (al) AAN' , dz.LOG_FORCE)
in Dashticz
blocks['vent_block'] 		= {idx: 532, width : 4,hide_data : true,icon: ' ',title: 'Ventilatie'}
in Domoticz
make a virtual text sensor (mine is in this example idx: 532)
renerene
Post by renerene »
Thank you madpatrick. Got it working
1) For testing I copied the same text three times and experimented a bit with "/n" symbol and string.char(10). But have not found a "new line" method yet. But good to see Dashticz shows multiple lines and breaks automaticly. That is a good starting point.
2) the reserved space for the icon and the title is a bit of a waste of space.
UPDATE:
ah, needs some manual adjustments...
