can I find script name in LUA code?
manjh
Post by manjh »
Is there a way to use the name of the current script in LUA, so I can use it in logging?
I know I can do it "hard coded", but it would be more elegant if there is a way to pull it...
Hans
manjh
Re: can I find script name in LUA code?
Post by manjh »
any ideas? Is there a simple way to use the script name in the LUA code?
Hans
lost
Post by lost »
manjh wrote: Monday 06 February 2023 9:21 any ideas? Is there a simple way to use the script name in the LUA code?
A quick search shows this possibility using a Lua debug module, if available in Lua interpreter build included with Domoticz?
https://stackoverflow.com/questions/214 ... rrent-file
But looks there is no luck as $0 in bash, __FILE in python or __FILE__ etc even here in good old C. Lua just misses this common feature builtin.
Doler
Post by Doler »
I use:
local SCRIPT_NAME = string.gsub(string.match(debug.getinfo(1, 'S').short_src, "[^/]+$"), '.lua', '')
in all my scripts.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
plugge
Post by plugge »
@Doler Nice! Very useful, thanks!
mgugu
Post by mgugu »
Doler wrote: Monday 06 February 2023 13:21 I use:
in all my scripts.
Excellent find !
manjh
Post by manjh »
lost wrote: Monday 06 February 2023 11:31
Yes...
Hans
manjh
Post by manjh »
in all my scripts.
Good tip, thank you. Although it does not really give me the actual name of the script, but rather the contents of the very first line of the script.
I could add your line of code to each script, but I might as well hard code the name as first LUA statement into SCRIPT_NAME.
Anyway, it gives me a way forward. Thanks.
Hans
