Is there a way to use the name of the current script in LUA, so I can use it in logging?
I know I can do it "hard coded", but it would be more elegant if there is a way to pull it...
can I find script name in LUA code?
- Domoticz version: 2020.2
Re: can I find script name in LUA code?
any ideas? Is there a simple way to use the script name in the LUA code?
Hans
A quick search shows this possibility using a Lua debug module, if available in Lua interpreter build included with Domoticz?
https://stackoverflow.com/questions/214 ... rrent-file
But looks there is no luck as $0 in bash, __FILE in python or __FILE__ etc even here in good old C. Lua just misses this common feature builtin.
I use: in all my scripts.
local SCRIPT_NAME = string.gsub(string.match(debug.getinfo(1, 'S').short_src, "[^/]+$"), '.lua', '')
Mark: Domoticz Beta on Raspberry Pi 4 running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - MySensors - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (plugin) - Zwave-js-ui - dzVents - Nodered
Excellent find !Doler wrote: ↑Monday 06 February 2023 13:21 I use:in all my scripts.Code: Select all
Yes...lost wrote: ↑Monday 06 February 2023 11:31Hello,
Hans
Good tip, thank you. Although it does not really give me the actual name of the script, but rather the contents of the very first line of the script.Doler wrote: ↑Monday 06 February 2023 13:21 I use:in all my scripts.Code: Select all
I could add your line of code to each script, but I might as well hard code the name as first LUA statement into SCRIPT_NAME.
Anyway, it gives me a way forward. Thanks.
Hans
