get a global (or persistent)counter to work in dzVents-script
RonkA
Domoticz version: 2025.1
Post by RonkA »
This post is the is start of my quest: viewtopic.php?t=39611
For another layer of difficulty i want to add is, when i press a button i can cycle through other lines of text on my lcd2004 display.
With the help from openAI i got a script in dzVents that in theory does wat i want but when it runs it gives an error.
Resolving this problem is a bridge to far for the artificial intelligence, essencialy it gave up:
If none of these steps solve the issue, you might consider posting the log files and more details about your setup in a domoticz forum. They will be able to help you troubleshoot the issue more effectively.
I have asked openAI to try and use a global counter, persistent data, user variables but everytime it failed.
One of the problems i found that Domoticz uses dzVents 3.1.8, openAI uses version version 3.8xxx, from than on i asked openAI to use version 3.1.8 to make the scripts.
OpenAI tried at some point to make something but it could'nt get it to work in dzVents but remade it into LUA, id prefer dzVents for getting the values from some devices.
So here we are, is there a way to get a (global) counter that counts from 1 to 3 and than resets to 1 so a buttonpress is sending different texts the display everytime..(There are 3 different texts in this script.)
OpenAI last script gives the following error:
Error: EventSystem: in Script #2: [string "..."]:13: attempt to index a nil value (global 'domoticz')
-- Create a global variable to store the counter
global = global or {}
global.counter = global.counter or 0
local value1 = 123
local value2 = 456
local value3 = 789
-- Get the switch device by name
local switch = domoticz.devices("Schakelaar op display2004")
-- Check if the switch is turned off
if switch.state == "Off" then
    -- Increment the counter
    if global.counter < 3 then
        global.counter = global.counter + 1
        global.counter = 1
    -- Check the value of the counter
    if global.counter == 1 then
        -- Log the message and open the URL
       -- domoticz.log('Buffervat bovenin: ' .. value3, domoticz.LOG_INFO)
        domoticz.openURL('http://192.168.178.220/control?cmd=lcd,1,1,Electrakosten%FE' .. value1 ..'EUR')
        domoticz.log('Waterkosten vandaag: ' .. value2, domoticz.LOG_INFO)
        domoticz.openURL('http://192.168.178.220/control?cmd=lcd,2,1,%FEkosten%FEwater%FE' .. value2 ..'EUR')
        domoticz.openURL('http://192.168.178.220/control?cmd=lcd,3,1,%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE')
    elseif global.counter == 2 then
        --domoticz.log('Buffervat bovenin: ' .. value3, domoticz.LOG_INFO)
        domoticz.openURL('http://192.168.178.220/control?cmd=lcd,1,1,%FE%FE%FE%FEbuffervat%FE' .. value3 ..'%DFC')
        domoticz.openURL('http://192.168.178.220/control?cmd=lcd,2,1,%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE%FE')
    elseif global.counter == 3 then
        domoticz.openURL('http://192.168.178.220/control?cmd=lcd,1,1,%FE%FE%FE%FE%FE%FE%FE%FETEST%FE%FE%FE%FE%FE%FE%FE%FE')
    -- Log the counter value
    domoticz.log("Counter value: " .. global.counter, domoticz.LOG_INFO)
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
willemd
Domoticz version: 2024.1
Re: get a global (or persistent)counter to work in dzVents-script
Post by willemd »
Sometimes you have to rely on your own intelligence .... and your ability to read the documentation ;-)
Your script does not have the structure of a dzVents script as explained here https://www.domoticz.com/wiki/DzVents:_ ... _scripting
RonkA
Post by RonkA »
Thanks willemd, Realy helpful. Can anybody else realy help me?
I suppose you could read the wiki section on dzvents global data https://www.domoticz.com/wiki/DzVents:_ ... _variables
But I do not think you need global data. Do you have multiple scripts using this data? If yes you need global data. If not you can use Script level persistent variables (see the wiki).
And also willemd is right, this is not a good dzVents script.
Also the error Error: EventSystem: in Script #2: [string "..."]:13: attempt to index a nil value (global 'domoticz') does not lead to anything in your script so it seems you copied only a part of your total script.
RonkA
Post by RonkA »
This is my now working dzVents script for getting some other info to send to my display than the standard text from an other script that updates every 20 seconds:
-- dit komt van openai
local logLevel = domoticz.LOG_ERROR
        devices = {'Schakelaar op display2004'},
        if (device.state == 'Off') then
                local sensor1 = domoticz.devices('Electra kosten vandaag')
                local sensor2 = domoticz.devices('Waterkosten vandaag')
                local sensor3 = domoticz.devices('Buffervat bovenin')
                local value1 = domoticz.utils.round(sensor1.sensorValue,2)
                local value2 = domoticz.utils.round(sensor2.sensorValue,2)
                local value3 = domoticz.utils.round(sensor3.temperature,0)
                domoticz.log('Electra kosten vandaag: ' .. value1, domoticz.LOG_INFO)
                domoticz.openURL('http://192.168.178.220/control?cmd=lcd,2,1,Electrakosten%FE' .. value1 ..'EUR')
                domoticz.openURL('http://192.168.178.220/control?cmd=lcd,3,1,%FEkosten%FEwater%FE' .. value2 ..'EUR')
This works ok.
Now i wanted to add more functionality, by pressing a button multiple times other messages would display. I thought it wouldn't be too difficult but Boy i was wrong..
Via trail and error i found out that the least difficult way would be to get a small counter to run between 1 to 3 and back to 1 every time the button is pressed.
Because i am not sure what is the best method to do this i tried(with 'help' of openai) persistent data, global data, Global persistent data, shared helpers but No Bueno.
For the persistent variables i made a global_data.lua file:
    helpers = {
        Buttonpress = 1
and saved it to NAS-1/docker/domoticz/scripts/dzVents/scripts/ as i understood from the wiki. but it doesnt work.
One of the many failed attempts:
        devices = { 'Schakelaar op display2004' }
    local commandArray = {}
    local buttonPressed = dzVents.globalData.getOrSet('Buttonpress', 1)
        if device.state == 'Off' then
            if buttonPress == 1 then
                commandArray['OpenURL']='http://192.168.178.220/control?cmd=lcd,1,1,Test%FE%FE%FE%FEbuffervat%FE' .. value3 ..'%DFC'
                dzVents.globalData.set('Buttonpress', 2)
            elseif buttonPress == 2 then
                commandArray['OpenURL']='http://192.168.178.220/control?cmd=lcd,1,1,Test%FEElectrakosten%FE' .. value1 ..'EUR'
                dzVents.globalData.set('Buttonpress', 3)
            elseif buttonPress == 3 then
                commandArray['OpenURL']='http://192.168.178.220/control?cmd=lcd,1,1,Test%FEkosten%FEwater%FE' .. value2 ..'EUR'
                dzVents.globalData.set('Buttonpress', 1)
   --   return commandArray
The attempt before this it was written without the commandarray command but it failed, i asked openai to rewrite with and made this, so Yeah i'm stuck.. :(
Well I think openAi is not a really experienced dzVents programmer...
Better try and think yourself.
RonkA
Post by RonkA »
thnx!
RonkA
Post by RonkA »
This is because this forum engine croped 3 empty lines from pasted text, this is where i state info over the script for myself.. The latter script i didn't remove this info...
Sorry about that.
willemd
Post by willemd »
For starters: You are checking on the value of ButtonPress (1, 2 or 3) but you have not defined what that is. You have defined ButtonPressed, which is not the same thing as ButtonPress.
You are probably getting an error message on that?
willemd
Post by willemd »
try this
    data = {
        buttonPress = { initial = 1},  -- this is the definition of the persistent variable for counting the number of times the button is pressed
        if (device.state == 'Off') then   -- so the button is pressed and then released, both changes trigger this script but the "off state" then executes the below lines
            domoticz.data.buttonPress=domoticz.data.buttonPress+1   -- increase the counter and reset to 1 if needed
            if domoticz.data.buttonPress>3 then
                domoticz.data.buttonPress=1
            if domoticz.data.buttonPress==1 then
                domoticz.openURL('http://192.168.178.220/control?cmd=lcd,1,1,%FE%FE%FE%FEbuffervat%FE' .. value3 ..'%DFC') -- I assume this is the command to update the display?
                if domoticz.data.buttonPress == 2 then
                    if domoticz.data.buttonPress == 3 then
RonkA
Post by RonkA »
Hi, if i run this immediatly this error occurs:
Error: EventSystem: in display Script #1: [string " local logLevel = domoticz.LOG_ERROR ..."]:1: attempt to index a nil value (global 'domoticz')
I see you use tabs very consistant, is this just good practice or is it mandatory to get the script to work correctly?
willemd
Post by willemd »
I think you can remove the first line and add the following just before the word "execute".
logging = {
		level = domoticz.LOG_INFO,
		marker = 'display test',
The tabs are just for readibility (and because I am used to python, where it is mandatory)
RonkA
Post by RonkA »
Replacing 1ine 1 gave:
So i placed line 5 to line 1:
,error gone but in the log this gives immediately:
Error: EventSystem: in display Script #1: [string "return { ..."]:3: attempt to index a nil value (global 'domoticz')
I have the funny feeling my dzvents is broken.. :?
willemd
Post by willemd »
I think the order of the sections matters. You should put the logging section just before the word "execute".
If I run below script I get the "testing the buttonpress script" message in the log file and the device state.
Always good to put log messages in between while doing development.
    data = {
    logging = {
        domoticz.log('testing the buttonpress script', domoticz.LOG_INFO)
        domoticz.log('device.state ' .. device.state, domoticz.LOG_INFO)
            domoticz.log('buttonpress value ' .. domoticz.data.buttonPress, domoticz.LOG_INFO)
Top
RonkA
Post by RonkA »
Yes, now we getting somewhere..
When i copied the second last script i pasted it over the wrong script... a lua script :oops:
Now i started with a Clean dzVents script and it came alive:
2023-01-21 20:27:02.545 Error: dzVents: Error: (3.1.8) display test: There was a problem writing the storage values
2023-01-21 20:27:02.545 Error: dzVents: Error: (3.1.8) display test: /opt/domoticz/dzVents/runtime/persistence.lua:24: /opt/domoticz/userdata/scripts/dzVents/data/__data_Script #1 displaytest 1.lua: No such file or directory
So made data directory and its alive..
A few buttonpresses cycles the texts as wanted! Hurray!! :D
Thank you for getting me out of the vortex of going insane.
