Buienradar stopped updating at 1:30
friso82
I noticed that Buienradar stopped updating ar 1:30 in the morning. Sensors are refreshed every 10 minutes, but no new data. No errors in the logfile.
Anyone else experience this?
Thanks! Friso
Thanks! Friso
friso82
Re: Buienradar stopped updating at 1:30
Checked the json output (https://data.buienradar.nl/2.0/feed/json) , but apparently the timestamp is also from around midnight, so I guess it's an error on the Buienradar side.
4 {25}
$id : 8
stationid : 6260
stationname : Meetstation De Bilt
lat : 52.1
lon : 5.18
regio : Utrecht
timestamp : 2023-01-01T00:50:00
weatherdescription : Zwaar bewolkt
iconurl : https://www.buienradar.nl/resources/images/icons/weather/30x30/cc.png
graphUrl : https://www.buienradar.nl/nederland/weerbericht/weergrafieken/cc
winddirection : ZW
airpressure : 1006.4
temperature : 15.6
groundtemperature : 14.8
feeltemperature : 13.7
visibility : 24100
windgusts : 16.3
windspeed : 9.4
windspeedBft : 5
humidity : 59
precipitation : 0
sunpower : 2
rainFallLast24Hour : 21.3
rainFallLastHour : 0
winddirectiondegrees : 219
- Domoticz version: 2025.1
Seems that Buienradar still has this issue....
tne7laa
I noticed today that I'm having the same problem. Maybe Buienradar has stopped/discontinued the service?
As we speak it seems to be resolved by Buienradar. Timestamp in json is now of today:
"timestamp":"2023-01-02T11:10:00"
hmm, and now all station info has disappeared from the json, so it seems Buienradar is still working on it....
tne7laa
I just changed station ID (it was Undefined in Domotics settings, maybe my mistake) now in log:
2023-01-02 11:21:49.917 Status: Buienradar: Using Station: Meetstation De Bilt (Utrecht), ID: 6260, Lat/Lon: 52.1,5.18
Maybe leave it alone a while...
- FireWizard
As far as I noticed.
This issue has been solved and everything is working normal.
DIKKEHENK
- Domoticz version: 2025.2
Hi there.. i do notice that the normal temperature feed has stopped with BR? I only have these left ?
best, dikke
best, dikke
- Schermafbeelding 2023-01-10 130943.jpg (290.49 KiB) Viewed 1671 times
- FireWizard
What do you receive, when you enter: https://data.buienradar.nl/2.0/feed/json in a browser?
DIKKEHENK
hi there... loads of this !
- Schermafbeelding 2023-01-10 160615.jpg (223.81 KiB) Viewed 1654 times
willemd
- Domoticz version: 2024.1
The normal temperature is part of the TempHumBaro.DIKKEHENK wrote: Tuesday 10 January 2023 13:11 Hi there.. i do notice that the normal temperature feed has stopped with BR? I only have these left ?
best, dikke
The one that is not in your list is the ground temperature, but looking at the sequence of your idx numbers it has never been there.
But then again, you have visbility in the list, which I don't have.
My buienradar is updating normally.
DIKKEHENK
ah ok, so this is basically all BR has to offer? If thats the case, fine, then i know all is well. Since i do had also ground temp, and that also dissapeard.
