I'm trying to migrate from zigbee2mqtt plugin to zigbee (mqtt) auto discovery. It seems to work well for most devices I have but fails on selector devices. I have Xiaomi Opple 2 band (WXCJKG12LM), Xiaomi Smart Switches (WXKG11LM, WXKG12LM).
Using zigbee2mqtt plugin I get working selector devices but with auto discovery I get a separate device for every state (off, single, double ...) as a push button. The worst thing is that these buttons aren't even working (Error sending switch command, check device/hardware).
Searching the forum, I can see that more people had (or have) the same problem but I cannot find what the current status is. Does anyone know?
Zigbee Auto Discovery status for selector devices?
Doler
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Doler
Re: Zigbee Auto Discovery status for selector devices?
No reaction so I guess status is unknown. Will have to stick to the plugin then since that is working.
vgerwen
- Domoticz version: 2024.4
I also moved from zigbee2mqtt plugin to zigbee (mqtt) auto discovery. The WXKG11LM pushbutton swich now appears as 4 switches (action_single, action_double, action_release and action_hold) in Domoticz. In the zigbee2mqtt plugin it appeared as one switch with the 4 states in treh device action field. This was much more convinient in the DzEvent scripts
Looking in the zigbee2mqtt frontend I see one switch with signle,double, release and hold as data of the action field.
Running Domoticz 2024.4 on Intel NUC5CPYH Ubuntu Docker
Hardware: RfxComm, Zigbee2MQTT - Conbee, P1 interface usb
Bertone
- Domoticz version: 2020.2
I have the same problem.
The selector with zigbee2mqtt, I had choice (in red in my picture) and now with Autodiscovery, new pushOn buttons are created. (others buttons on my pictures)
- selector.PNG (78.52 KiB) Viewed 723 times
Bertone
I want to use my Xiaomi Switch to control my home alarm.
One Click to start for exemple and double to stop.
I tried to use event (Blocky), created a Dummy (Switch) and nothing happens.
Do you have a solution ?
- issue_mqtt.png (69.81 KiB) Viewed 708 times
Bertone
I found a solution with a blocky script :
If that could help someone later
