Reading setpoint from Shelly TRV  [Solved]
vspamn
Domoticz version: 2022.2
Post by vspamn »
I wrote a script to read the setpoint temp from a shelly valve. It works, I however keep getting the following error in my logs (which is annoying).
Error: dzVents: Error: (3.1.8) ...scripts/Thermostaat studeerkamer (update connection).lua:39: attempt to index a nil value (field 'target_t')
The error is caused because the field "target_t" is indeed empty. Is there another way to obtain the value of shellyvalve.target_t.value?
-- DzVents script for update of set temperature Shelly Valve
local IPADDRESS = 'xx'                                            -- IP address
local USER = 'xx'                                                       -- login credentials
local PASSWORD = 'xx'                              -- login credentials
local THERMOSTAAT = 'Thermostaat studeerkamer'                              -- Thermostaat domoticz device name
		timer = {
			'every minute'
		httpResponses = {
			'trigger'
	execute = function(dz, item)
		if (item.isTimer) then
			dz.openURL({
				url = 'http://' .. USER .. ':' .. PASSWORD .. '@' .. IPADDRESS .. '/thermostat/0',
				method = 'GET',
				callback = 'trigger',
		if (item.isHTTPResponse) then
			if (item.ok) then
			   -- Parsing JSON data and interpreting data...
			   dz.log('processing data...', dz.LOG_INFO)
			   local shellyvalve = dz.utils.fromJSON(item.data)
			   local setpointshellyvalve = shellyvalve.target_t.value
			   -- Updating domoticz devices
			   dz.devices(THERMOSTAAT).updateSetPoint(setpointshellyvalve).silent()
		       dz.log('HTTP response error', dz.LOG_ERROR)
Domoticz version: 2025.1
Re: Reading setpoint from Shelly TRV
You can check first if value ~= nil then updateSetPoint() to prevent this error.
Addition, if the value should not sometimes be nil but a real number can jou post the JSON that came out of '/thermostat/0'?
HvdW
Domoticz version: 2023.2
Post by HvdW »
Maybe dump table gives the information you need.
Bugs bug me.
vspamn
Post by vspamn »
The JSON format that comes out of '/thermostat/0' is:
{"pos":100.0,"target_t":{"enabled":true,"value":19.5,"value_op":8.0,"units":"C"},"tmp":{"value":19.5,"units":"C","is_valid":true},"schedule":false,"schedule_profile":1,"boost_minutes":0,"window_open":false}
The dumpTable from Domoticz shows:
2023-01-04 10:17:01.463 Status: dzVents: > boost_minutes: 0
2023-01-04 10:17:01.463 Status: dzVents: > target_t:
2023-01-04 10:17:01.463 Status: dzVents: > enabled: true
2023-01-04 10:17:01.463 Status: dzVents: > units: C
2023-01-04 10:17:01.464 Status: dzVents: > value: 19.5
2023-01-04 10:17:01.464 Status: dzVents: > value_op: 8.0
2023-01-04 10:17:01.464 Status: dzVents: > window_open: false
2023-01-04 10:17:01.464 Status: dzVents: > schedule_profile: 1
2023-01-04 10:17:01.464 Status: dzVents: > schedule: false
2023-01-04 10:17:01.464 Status: dzVents: > pos: 99.1
2023-01-04 10:17:01.464 Status: dzVents: > tmp:
2023-01-04 10:17:01.464 Status: dzVents: > is_valid: true
2023-01-04 10:17:01.464 Status: dzVents: > value: 19.6
2023-01-04 10:17:01.464 Status: dzVents: > units: C
As you can see, this is exactly my difficulty, I "need" target_t to point to the correct "value", but target_t does not contain a value itself.
Seems OK though....
What did you dumpTable? shellyvalve or item.json?
What if you change line
into
local shellyvalve = item.json
Edit:
You could also try to use
local setpointshellyvalve = item.json.target_t.value
and remove the line
vspamn
Post by vspamn »
I let the dumpTable run for a bit and now see that the data is being mixed up with another script. The dumpTable sometimes shows the correct json data of the Shelly TRV, but sometimes shows the data of another thermostat.
I used the script of the other thermostat (see below for the relevant part of it) as a basis for the Shelly TRV script, but I probably need to differentiate. Any tips how to do so?
		timer = {
			'every minute'
		httpResponses = {
			'trigger'
			domoticz.openURL({
				url = 'http://' .. USER .. ':' .. PASSWORD .. '@' .. IPADDRESS .. '/protect/data.json?heater=0',
				method = 'GET',
			if (item.ok) then
			   domoticz.log('processing data...', domoticz.LOG_INFO)
			   local intergas = domoticz.utils.fromJSON(item.data)
			   local roomtemperature = domoticz.utils.round((intergas.room_temp_1_lsb + intergas.room_temp_1_msb * 256) / 100, 1)
Re: Reading setpoint from Shelly TRV  [Solved]
They both use value "trigger" as a httpRespones/callback value
Use a unique httpResponses/callback value for each script.
vspamn
Post by vspamn »
Ah, that did the trick, thanks a lot!
